I installed NVidia drivers for GeForce GT 635M. Last version 390.
| NVIDIA-SMI 390.129 Driver Version: 390.129 |
| 0 GeForce GT 635M Off | 00000000:01:00.0 N/A | N/A |
| N/A 51C P8 N/A / N/A | 248MiB / 1985MiB | N/A Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 Not Supported |
https://docs.nvidia.com/deploy/cuda-compatibility/index.html#binary-compatibility
if I understand correctly, I need to install CUDA 9.0 (9.0.76). But I can see only Installer for Linux Ubuntu 17.04 x86_64.
I tried to get Installer for Linux Ubuntu 17.04 x86_64
$ sudo dpkg -i cuda-repo-ubuntu1704_9.0.176-1_amd64.deb
$ sudo apt-key adv --fetch-keys https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1704/x86_64/7fa2af80.pub
$ sudo apt-get update
$ sudo apt-get install cuda
and recieved results
Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
cuda: Depends: cuda-9-1 (>= 9.1.85) but is not to be installed
E: Unable to correct problems, you have held broken packages.
I tried install CUDA 9.0 (9.0.76) and CUDA 9.0 (9.1.85), but in all cases have trouble.
Can you help me compile compatible versions?
