Nowadays I have installed a nvidid driver in a server machine,The driver is installed through the Ubuntu philosophy system, not the“.run” file downloaded from the official website. But I encountered a troublesome problem: as shown in the title:
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
When I was using the driver installation on the official website, the following issues occurred:
An alternate method of installing the NVIDIA driver was detected. (This is usually a package provided by your distributor.) A driver installed via that method may integrate better with your system than a driver installed by nvidia-installer.
Besides,The following issues have occurred again:
Unable to load the kernel module 'nvidia.ko'. This happens most
frequently when this kernel module was built against the wrong or
improperly configured kernel sources, with a version of gcc that
differs from the one used to build the target kernel, or if another
driver, such as nouveau, is present and prevents the NVIDIA kernel
module from obtaining ownership of the NVIDIA device(s), or no NVIDIA
device installed in this system is supported by this NVIDIA Linux
graphics driver release.
Please see the log entries 'Kernel module load error' and 'Kernel
messages' at the end of the file '/var/log/nvidia-installer.log' for
more information.
And then I grabbed it ‘/var/log/nvidia-installer.log’ It has already been uploaded by me. nvidia-installer.log (35.7 KB)
I have also tried other forum methods, such as:
Many other posts say that, if you update the Linux kernel, the Nvidia driver that was installed during the older kernel period will not compatible with the updated kernel. The solution is to use use (Dynamic Kernel Module Support) to install a new kernel-compatible files for the drivers, like this:dkms:
The driver version can be found by the command .whereis nvidia However, this solution didn’t work for me either, because even my driver was installed after the kernel update.
$ dpkg -l | grep nvidia
ii gpustat 0.6.0-1 all pretty nvidia device monitor
ii libnvidia-cfg1-530:amd64 530.30.02-0ubuntu1 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-515 515.105.01-0ubuntu1 all Shared files used by the NVIDIA libraries
ii libnvidia-common-530 530.30.02-0ubuntu1 all Shared files used by the NVIDIA libraries
rc libnvidia-compute-515:amd64 515.105.01-0ubuntu0.22.04.1 amd64 NVIDIA libcompute package
ii libnvidia-compute-530:amd64 530.30.02-0ubuntu1 amd64 NVIDIA libcompute package
ii libnvidia-compute-530:i386 530.30.02-0ubuntu1 i386 NVIDIA libcompute package
iU libnvidia-container-tools 1.14.5-1 amd64 NVIDIA container runtime library (command-line tools)
iU libnvidia-container1:amd64 1.14.5-1 amd64 NVIDIA container runtime library
ii libnvidia-decode-530:amd64 530.30.02-0ubuntu1 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-decode-530:i386 530.30.02-0ubuntu1 i386 NVIDIA Video Decoding runtime libraries
ii libnvidia-encode-530:amd64 530.30.02-0ubuntu1 amd64 NVENC Video Encoding runtime library
ii libnvidia-encode-530:i386 530.30.02-0ubuntu1 i386 NVENC Video Encoding runtime library
ii libnvidia-extra-530:amd64 530.30.02-0ubuntu1 amd64 Extra libraries for the NVIDIA driver
ii libnvidia-fbc1-530:amd64 530.30.02-0ubuntu1 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-fbc1-530:i386 530.30.02-0ubuntu1 i386 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-530:amd64 530.30.02-0ubuntu1 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-gl-530:i386 530.30.02-0ubuntu1 i386 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
rc nvidia-compute-utils-515 515.105.01-0ubuntu0.22.04.1 amd64 NVIDIA compute utilities
ii nvidia-compute-utils-530 530.30.02-0ubuntu1 amd64 NVIDIA compute utilities
ii nvidia-container-toolkit 1.13.1-1 amd64 NVIDIA Container toolkit
ii nvidia-container-toolkit-base 1.13.1-1 amd64 NVIDIA Container Toolkit Base
rc nvidia-dkms-515 515.105.01-0ubuntu0.22.04.1 amd64 NVIDIA DKMS package
ii nvidia-dkms-530 530.30.02-0ubuntu1 amd64 NVIDIA DKMS package
ii nvidia-docker2 2.13.0-1 all nvidia-docker CLI wrapper
ii nvidia-driver-530 530.30.02-0ubuntu1 amd64 NVIDIA driver metapackage
rc nvidia-kernel-common-515 515.105.01-0ubuntu0.22.04.1 amd64 Shared files used with the kernel module
ii nvidia-kernel-common-530 530.30.02-0ubuntu1 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-530 530.30.02-0ubuntu1 amd64 NVIDIA kernel source package
ii nvidia-modprobe 530.30.02-0ubuntu1 amd64 Load the NVIDIA kernel driver and create device files
ii nvidia-prime 0.8.17.1 all Tools to enable NVIDIA's Prime
ii nvidia-settings 530.30.02-0ubuntu1 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-530 530.30.02-0ubuntu1 amd64 NVIDIA driver support binaries
ii screen-resolution-extra 0.18.2 all Extension for the nvidia-settings control panel
ii xserver-xorg-video-nvidia-530 530.30.02-0ubuntu1 amd64 NVIDIA binary Xorg driver
(base) mona@DOS:~$ nvidia-smi
and
(base) mona@DOS:~$ nvcc --version
Copyright (c) 2005-2022 NVIDIA Corporation
Built on Wed_Jun__8_16:49:14_PDT_2022
Cuda compilation tools, release 11.7, V11.7.99
Build cuda_11.7.r11.7/compiler.31442593_0
(base) mona@DOS:~$ uname -a
Linux DOS 6.5.0-21-generic #21~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Fri Feb 9 13:32:52 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
(base) mona@DOS:~$ lsb_release -a
LSB Version: core-11.1.0ubuntu4-noarch:security-11.1.0ubuntu4-noarch
Distributor ID: Ubuntu
Description: Ubuntu 22.04.4 LTS
Release: 22.04
Codename: jammy
This problem happened after the training phase of nvidia tao for CenterPose finished.
Feel free to let me know if further information may be needed.
My end goal is to run this notebook in offline mode and train, evaluate, and visualize centerpose. Since training couldn’t be done in the notebook (notebook keeps crashing), I converted it to an offline Python script listed below.
(base) mona@DOS:~/tao_tutorials/notebooks/tao_launcher_starter_kit/centerpose$ cat train_centerpose.py
import os
import numpy as np
import cv2
import glob
import tqdm
import json
import requests
import shutil
import tensorflow as tf
import warnings
from scipy.spatial.transform import Rotation as R
import subprocess
import matplotlib.pyplot as plt
from math import ceil
os.environ["PATH"]="{}/ngccli/ngc-cli:{}".format(os.getenv("LOCAL_PROJECT_DIR", ""), os.getenv("PATH", ""))
os.environ["LOCAL_PROJECT_DIR"] = "/hdd/tao-experiments"
os.environ["HOST_DATA_DIR"] = os.path.join(os.getenv("LOCAL_PROJECT_DIR", os.getcwd()), "data", "centerpose")
os.environ["HOST_RESULTS_DIR"] = os.path.join(os.getenv("LOCAL_PROJECT_DIR", os.getcwd()), "centerpose", "results")
# Set this path if you don't run the notebook from the samples directory.
# %env NOTEBOOK_ROOT=~/tao-samples/centerpose
# The sample spec files are present in the same path as the downloaded samples.
os.environ["HOST_SPECS_DIR"] = os.path.join(
os.getenv("NOTEBOOK_ROOT", os.getcwd()),
"specs"
print('host specs dir: ', os.environ["HOST_SPECS_DIR"])
# The data is saved here
DATA_DIR = '/data'
MODEL_DIR = '/model'
SPECS_DIR = '/specs'
RESULTS_DIR = '/results'
mounts_file = os.path.expanduser("~/.tao_mounts.json")
tao_configs = {
"Mounts":[
# Mapping the Local project directory
"source": os.environ["LOCAL_PROJECT_DIR"],
"destination": "/workspace/tao-experiments"
"source": os.environ["HOST_DATA_DIR"],
"destination": "/data"
"source": os.environ["HOST_SPECS_DIR"],
"destination": "/specs"
"source": os.environ["HOST_RESULTS_DIR"],
"destination": "/results"
"DockerOptions": {
"shm_size": "16G",
"ulimits": {
"memlock": -1,
"stack": 67108864
"user": "{}:{}".format(os.getuid(), os.getgid()),
"network": "host"
with open(mounts_file, "w") as mfile:
json.dump(tao_configs, mfile, indent=4)
cmd = "cat ~/.tao_mounts.json"
result = subprocess.run(cmd, shell=True, stdout=subprocess.PIPE, stderr=subprocess.PIPE)
print(result.stdout.decode("utf-8"))
cmd = "tao info --verbose"
def get_image(feature, shape=None):
"""Decode the tensorflow image example."""
image = cv2.imdecode(
np.asarray(bytearray(feature.bytes_list.value[0]), dtype=np.uint8),
cv2.IMREAD_ANYCOLOR | cv2.IMREAD_ANYDEPTH)
if len(image.shape) > 2 and image.shape[2] > 1:
image = cv2.cvtColor(image, cv2.COLOR_BGR2RGB)
if shape is not None:
image = cv2.resize(image, shape)
return image
def parse_plane(example):
"""Parses plane from a tensorflow example."""
fm = example.features.feature
if "plane/center" in fm and "plane/normal" in fm:
center = fm["plane/center"].float_list.value
center = np.asarray(center)
normal = fm["plane/normal"].float_list.value
normal = np.asarray(normal)
return center, normal
else:
return None
def parse_example(example):
"""Parse the image example data"""
# Extract images, setting the input shape for Objectron Dataset
image = get_image(fm["image/encoded"], shape=(600, 800))
filename = fm["image/filename"].bytes_list.value[0].decode("utf-8")
filename = filename.replace('/', '_')
image_id = np.asarray(fm["image/id"].int64_list.value)[0]
label = {}
visibilities = fm["object/visibility"].float_list.value
visibilities = np.asarray(visibilities)
index = visibilities > 0.1
if "point_2d" in fm:
points_2d = fm["point_2d"].float_list.value
points_2d = np.asarray(points_2d).reshape((-1, 9, 3))[..., :2]
if "point_3d" in fm:
points_3d = fm["point_3d"].float_list.value
points_3d = np.asarray(points_3d).reshape((-1, 9, 3))
if "object/scale" in fm:
obj_scale = fm["object/scale"].float_list.value
obj_scale = np.asarray(obj_scale).reshape((-1, 3))
if "object/translation" in fm:
obj_trans = fm["object/translation"].float_list.value
obj_trans = np.asarray(obj_trans).reshape((-1, 3))
if "object/orientation" in fm:
obj_ori = fm["object/orientation"].float_list.value
obj_ori = np.asarray(obj_ori).reshape((-1, 3, 3))
label["2d_instance"] = points_2d[index]
label["3d_instance"] = points_3d[index]
label["scale_instance"] = obj_scale[index]
label["translation"] = obj_trans[index]
label["orientation"] = obj_ori[index]
label["image_id"] = image_id
label["visibility"] = visibilities[index]
label['ORI_INDEX'] = np.argwhere(index).flatten()
label['ORI_NUM_INSTANCE'] = len(index)
return image, label, filename
def parse_camera(example):
"""Parse the camera calibration data"""
if "camera/projection" in fm:
proj = fm["camera/projection"].float_list.value
proj = np.asarray(proj).reshape((4, 4))
else:
proj = None
if "camera/view" in fm:
view = fm["camera/view"].float_list.value
view = np.asarray(view).reshape((4, 4))
else:
view = None
if "camera/intrinsics" in fm:
intrinsic = fm["camera/intrinsics"].float_list.value
intrinsic = np.asarray(intrinsic).reshape((3, 3))
else:
intrinsic = None
return proj, view, intrinsic
def partition(lst, n):
"""Equally split the video lists."""
division = len(lst) / float(n) if n else len(lst)
return [lst[int(np.round(division * i)): int(np.round(division * (i + 1)))] for i in range(n)]
OBJECTRON_BUCKET = "gs://objectron/v1/records_shuffled"
PUBLIC_URL = "https://storage.googleapis.com/objectron"
SAVE_DIR = os.getenv("HOST_DATA_DIR", os.getcwd())
# Please add the "test" into the array if you want to evaluate the whole testing set. It requires at least 30GB to download the bike category.
# DATA_DISTRIBUTION = ['train', 'val', 'test']
DATA_DISTRIBUTION = ['train', 'val']
# Note that the sample spec is not meant to produce SOTA accuracy on Objectron dataset.
# To reproduce SOTA, you should set `TRAIN_FR` as 15 and `DATA_DOWNLOAD` as -1 to match the original parameters.
TRAIN_FR = 30
VAL_FR = 60
TEST_FR = 1
DATA_DOWNLOAD = 10000
# Please select the specific categories that you want to train the CenterPose model.
# CATEGORIES = ['bike', 'book', 'bottle', 'camera', 'cereal_box', 'chair', 'laptop', 'shoe']
CATEGORIES = ['bike']
memory_free = shutil.disk_usage(SAVE_DIR).free
if len(CATEGORIES) >= 8 and memory_free < 4.4E12:
warnings.warn("No enough space for downloading all 8 categories.")
for c in CATEGORIES:
for dist in DATA_DISTRIBUTION:
# Download the tfrecord files
if dist in ['test', 'val']:
eval_data = f'/{c}/{c}_test*'
blob_path = PUBLIC_URL + f"/v1/index/{c}_annotations_test"
elif dist in ['train']:
eval_data = f'/{c}/{c}_train*'
blob_path = PUBLIC_URL + f"/v1/index/{c}_annotations_train"
else:
raise ValueError("No specific data distribution settings.")
eval_shards = tf.io.gfile.glob(OBJECTRON_BUCKET + eval_data)
ds = tf.data.TFRecordDataset(eval_shards).take(DATA_DOWNLOAD)
with tf.io.TFRecordWriter(f'{SAVE_DIR}/{c}_{dist}.tfrecord') as file_writer:
for serialized in tqdm.tqdm(ds):
example = tf.train.Example.FromString(serialized.numpy())
record_bytes = example.SerializeToString()
file_writer.write(record_bytes)
# Get the video ids
video_ids = requests.get(blob_path).text
video_ids = [i.replace('/', '_') for i in video_ids.split('\n')]
# Work on a subset of the videos for each round, where the subset is equally split
video_ids_split = partition(video_ids, int(np.floor(len(video_ids) / int(len(video_ids) / 2))))
# Decode the tfrecord files
tfdata = f'{SAVE_DIR}/{c}_{dist}*'
eval_shards = tf.io.gfile.glob(tfdata)
new_ds = tf.data.TFRecordDataset(eval_shards).take(-1)
for subset in video_ids_split:
videos = {}
for serialized in tqdm.tqdm(new_ds):
# Group according to video_id & image_id
video_id = filename.replace('/', '_')
# Sometimes, data is too big to save, so we only focus on a small subset instead.
if video_id not in subset:
continue
if video_id in videos:
videos[video_id].append((image_id, example))
else:
videos[video_id] = []
# Saved the decoded tfrecord files.
save_tfrecords = f'{SAVE_DIR}/{c}/tfrecords/{dist}'
if not os.path.exists(save_tfrecords):
os.makedirs(save_tfrecords)
for video_id in tqdm.tqdm(videos):
with tf.io.TFRecordWriter(f'{save_tfrecords}/{video_id}.tfrecord') as file_writer:
for image_data in videos[video_id]:
record_bytes = image_data[1].SerializeToString()
# Extract the images and ground truth.
videos = [os.path.splitext(os.path.basename(i))[0] for i in glob.glob(f'{save_tfrecords}/*.tfrecord')]
frame_rate = TRAIN_FR
elif dist in ['val']:
frame_rate = VAL_FR
elif dist in ['test']:
frame_rate = TEST_FR
else:
for idx, key in enumerate(videos):
print(f'Video {idx}, {key}:')
ds = tf.data.TFRecordDataset(f'{save_tfrecords}/{key}.tfrecord').take(-1)
image, label, prefix = parse_example(example)
frame_id = label['image_id']
if int(frame_id) % frame_rate == 0:
proj, view, cam_intrinsic = parse_camera(example)
plane = parse_plane(example)
cam_intrinsic[:2, :3] = cam_intrinsic[:2, :3] / 2.4
center, normal = plane
height, width, _ = image.shape
im_bgr = cv2.cvtColor(image, cv2.COLOR_RGB2BGR)
dict_out = {
"camera_data" : {
"width" : width,
'height' : height,
'camera_view_matrix':view.tolist(),
'camera_projection_matrix':proj.tolist(),
'intrinsics':{
'fx':cam_intrinsic[1][1],
'fy':cam_intrinsic[0][0],
'cx':cam_intrinsic[1][2],
'cy':cam_intrinsic[0][2]
"objects" : [],
"AR_data":{
'plane_center':[center[0],
center[1],
center[2]],
'plane_normal':[normal[0],
normal[1],
normal[2]]
for object_id in range(len(label['2d_instance'])):
object_categories = c
quaternion = R.from_matrix(label['orientation'][object_id]).as_quat()
trans = label['translation'][object_id]
projected_keypoints = label['2d_instance'][object_id]
projected_keypoints[:, 0] *= width
projected_keypoints[:, 1] *= height
object_scale = label['scale_instance'][object_id]
keypoints_3d = label['3d_instance'][object_id]
visibility = label['visibility'][object_id]
dict_obj={
'class': object_categories,
'name': object_categories+'_'+str(object_id),
'provenance': 'objectron',
'location': trans.tolist(),
'quaternion_xyzw': quaternion.tolist(),
'projected_cuboid': projected_keypoints.tolist(),
'scale': object_scale.tolist(),
'keypoints_3d': keypoints_3d.tolist(),
'visibility': visibility.tolist()
# Final export
dict_out['objects'].append(dict_obj)
save_path = f"{SAVE_DIR}/{c}/{dist}/{prefix}/"
if not os.path.exists(save_path):
os.makedirs(save_path)
filename = f"{save_path}/{str(frame_id).zfill(5)}.json"
with open(filename, 'w+') as fp:
json.dump(dict_out, fp, indent=4, sort_keys=True)
cv2.imwrite(f"{save_path}/{str(frame_id).zfill(5)}.png", im_bgr)
cmd = "echo $HOST_DATA_DIR"
# Pull pretrained model from NGC
print("Check if model is downloaded into dir.")
cmd= "ls -l $HOST_RESULTS_DIR/pretrained_models/pretrained_fan_classification_nvimagenet_vfan_small_hybrid_nvimagenet"
print("For multi-GPU, change num_gpus in train.yaml based on your machine or pass --gpus to the cli.")
# If you face out of memory issue, you may reduce the batch size in the spec file by passing dataset. batch_size=2
#!tao model centerpose train -e $SPECS_DIR/train.yaml results_dir=$RESULTS_DIR/
# You can set NUM_EPOCH to the epoch corresponding to any saved checkpoint
#%env NUM_EPOCH=39
NUM_EPOCH=39
# Get the name of the checkpoint corresponding to your set epoch
#tmp=!ls $HOST_RESULTS_DIR/train/*.pth | grep epoch=0$NUM_EPOCH
#%env CHECKPOINT={tmp[0]}
cmd = 'ls $HOST_RESULTS_DIR/train/*.pth | grep epoch=0$NUM_EPOCH'
tmp = subprocess.run(cmd, shell=True, stdout=subprocess.PIPE, stderr=subprocess.PIPE)
print(tmp.stdout.decode("utf-8"))
#CHECKPOINT = {tmp[0]}
CHECKPOINT = "/hdd/tao-experiments/centerpose/results/pretrained_models/pretrained_fan_classification_nvimagenet_vfan_small_hybrid_nvimagenet/fan_small_hybrid_nvimagenet.pth" #MONA fix this
print('Rename a trained model: ')
print('---------------------')
cmd = "cp $CHECKPOINT $HOST_RESULTS_DIR/train/centerpose_model.pth"
cmd = "ls -ltrh $HOST_RESULTS_DIR/train/centerpose_model.pth"
#!cp $CHECKPOINT $HOST_RESULTS_DIR/train/centerpose_model.pth
#!ls -ltrh $HOST_RESULTS_DIR/train/centerpose_model.pth
# Evaluate on TAO model
cmd = "tao model centerpose evaluate -e $SPECS_DIR/evaluate.yaml evaluate.checkpoint=$RESULTS_DIR/train/centerpose_model.pth results_dir=$RESULTS_DIR"
cmd = "tao model centerpose inference -e $SPECS_DIR/infer.yaml inference.checkpoint=$RESULTS_DIR/train/centerpose_model.pth results_dir=$RESULTS_DIR"
valid_image_ext = ['.png']
def visualize_images(output_path, num_cols=4, num_images=10):
num_rows = int(ceil(float(num_images) / float(num_cols)))
f, axarr = plt.subplots(num_rows, num_cols, figsize=[40,30])
f.tight_layout()
a = [os.path.join(output_path, image) for image in os.listdir(output_path)
if os.path.splitext(image)[1].lower() in valid_image_ext]
for idx, img_path in enumerate(a[:num_images]):
col_id = idx % num_cols
row_id = idx // num_cols
img = plt.imread(img_path)
axarr[row_id, col_id].imshow(img)
# Visualizing the sample images.
# Note that the sample spec is not meant to produce SOTA (state-of-the-art) accuracy on Objectron dataset.
IMAGE_DIR = os.path.join(os.environ['HOST_RESULTS_DIR'], "inference")
COLS = 2 # number of columns in the visualizer grid.
IMAGES = 4 # number of images to visualize.
visualize_images(IMAGE_DIR, num_cols=COLS, num_images=IMAGES)
cmd = "mkdir -p $HOST_RESULTS_DIR/export"
# Export the RGB model to ONNX model
cmd = "tao model centerpose export -e $SPECS_DIR/export.yaml export.checkpoint=$RESULTS_DIR/train/centerpose_model.pth export.onnx_file=$RESULTS_DIR/export/centerpose_model.onnx"
