NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Tesla v100 GPU installed on HP Proliant DL380 running RHEL 9.4
Tesla v100 GPU installed on HP Proliant DL380 running RHEL 9.4. SMI Fails to launch
Posted on May 28, 2025 10:28 AM
I have a Tesla v100 installed in my HP Proliant DL380 gen8 server running RHEL 9.4
I’m getting error:
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
attached is bug report from
# /usr/bin/nvidia-bug-report.sh
nvidia-bug-report.log (2.3 MB)
info and steps:
uname -a
Linux hp1 5.14.0-427.35.1.el9_4.x86_64 #1 SMP PREEMPT_DYNAMIC Fri Aug 30 15:47:10 EDT 2024 x86_64 x86_64 x86_64 GNU/Linux
uname -r
modinfo nvidia | grep ^version
version: 570.124.06
nvidia-bug-report.logdownloaded driver:
-rw-r–r–. 1 root root 531810314 Feb 27 01:19 nvidia-driver-local-repo-rhel9-570.124.06-1.0-1.x86_64.rpm
followed instructions for RHEL 9 on 1. Introduction — NVIDIA Driver Installation Guide r570 documentation
  1. dnf install kernel-devel-matched kernel-headers
************************************************** OUTPUT *************************************************
Updating Subscription Management repositories.
Last metadata expiration check: 1:27:16 ago on Wed 09 Apr 2025 09:56:20 AM EDT.
Package kernel-devel-matched-5.14.0-427.35.1.el9_4.x86_64 is already installed.
Package kernel-headers-5.14.0-427.35.1.el9_4.x86_64 is already installed.
Dependencies resolved.
Package Architecture Version Repository Size
Installing:
kernel-core x86_64 5.14.0-503.35.1.el9_5 rhel-9-for-x86_64-baseos-rpms 18 M
kernel-devel x86_64 5.14.0-503.35.1.el9_5 rhel-9-for-x86_64-appstream-rpms 22 M
kernel-modules-core x86_64 5.14.0-503.35.1.el9_5 rhel-9-for-x86_64-baseos-rpms 31 M
Upgrading:
kernel-devel-matched x86_64 5.14.0-503.35.1.el9_5 rhel-9-for-x86_64-appstream-rpms 2.0 M
kernel-headers x86_64 5.14.0-503.35.1.el9_5 rhel-9-for-x86_64-appstream-rpms 3.8 M
Transaction Summary
Install 3 Packages
Upgrade 2 Packages
Total download size: 76 M
Is this ok [y/N]: y
Downloading Packages:
(1/5): kernel-core-5.14.0-503.35.1.el9_5.x86_64.rpm 7.5 MB/s | 18 MB 00:02
(2/5): kernel-devel-matched-5.14.0-503.35.1.el9_5.x86_64.rpm 5.3 MB/s | 2.0 MB 00:00
(3/5): kernel-devel-5.14.0-503.35.1.el9_5.x86_64.rpm 7.3 MB/s | 22 MB 00:03
(4/5): kernel-headers-5.14.0-503.35.1.el9_5.x86_64.rpm 7.5 MB/s | 3.8 MB 00:00
(5/5): kernel-modules-core-5.14.0-503.35.1.el9_5.x86_64.rpm 8.5 MB/s | 31 MB 00:03
Total 21 MB/s | 76 MB 00:03
Running transaction check
Transaction check succeeded.
Running transaction test
Transaction test succeeded.
Running transaction
Preparing :
Installing : kernel-modules-core-5.14.0-503.35.1.el9_5.x86_64
Installing : kernel-core-5.14.0-503.35.1.el9_5.x86_64
Running scriptlet: kernel-core-5.14.0-503.35.1.el9_5.x86_64
Installing : kernel-devel-5.14.0-503.35.1.el9_5.x86_64
Running scriptlet: kernel-devel-5.14.0-503.35.1.el9_5.x86_64
Upgrading : kernel-devel-matched-5.14.0-503.35.1.el9_5.x86_64
Upgrading : kernel-headers-5.14.0-503.35.1.el9_5.x86_64
Cleanup : kernel-headers-5.14.0-427.35.1.el9_4.x86_64
Cleanup : kernel-devel-matched-5.14.0-427.35.1.el9_4.x86_64
Running scriptlet: kernel-modules-core-5.14.0-503.35.1.el9_5.x
Sign command: /lib/modules/5.14.0-503.35.1.el9_5.x86_64/build/scripts/sign-file
Signing key: /var/lib/dkms/mok.key
Public certificate (MOK): /var/lib/dkms/mok.pub
Autoinstall of module nvidia/570.124.06 for kernel 5.14.0-503.35.1.el9_5.x86_64 (x86_64)
Cleaning build area… done.
Building module(s)… done.
Signing module /var/lib/dkms/nvidia/570.124.06/build/nvidia.ko
Signing module /var/lib/dkms/nvidia/570.124.06/build/nvidia-modeset.ko
Signing module /var/lib/dkms/nvidia/570.124.06/build/nvidia-drm.ko
Signing module /var/lib/dkms/nvidia/570.124.06/build/nvidia-uvm.ko
Signing module /var/lib/dkms/nvidia/570.124.06/build/nvidia-peermem.ko
Installing /lib/modules/5.14.0-503.35.1.el9_5.x86_64/extra/nvidia.ko.xz
Installing /lib/modules/5.14.0-503.35.1.el9_5.x86_64/extra/nvidia-modeset.ko.xz
Installing /lib/modules/5.14.0-503.35.1.el9_5.x86_64/extra/nvidia-drm.ko.xz
Installing /lib/modules/5.14.0-503.35.1.el9_5.x86_64/extra/nvidia-uvm.ko.xz
Installing /lib/modules/5.14.0-503.35.1.el9_5.x86_64/extra/nvidia-peermem.ko.xz
Running depmod… done.
Autoinstall on 5.14.0-503.35.1.el9_5.x86_64 succeeded for module(s) nvidia.
Running scriptlet: kernel-devel-matched-5.14.0-427.35.1.el9_4.x86_64
Verifying : kernel-core-5.14.0-503.35.1.el9_5.x86_64
Verifying : kernel-modules-core-5.14.0-503.35.1.el9_5.x86_64
Verifying : kernel-devel-5.14.0-503.35.1.el9_5.x86_64
Verifying : kernel-devel-matched-5.14.0-503.35.1.el9_5.x86_64
Verifying : kernel-devel-matched-5.14.0-427.35.1.el9_4.x86_64
Verifying : kernel-headers-5.14.0-503.35.1.el9_5.x86_64
Verifying : kernel-headers-5.14.0-427.35.1.el9_4.x86_64
Installed products updated.
Upgraded:
kernel-devel-matched-5.14.0-503.35.1.el9_5.x86_64 kernel-headers-5.14.0-503.35.1.el9_5.x86_64
Installed:
kernel-core-5.14.0-503.35.1.el9_5.x86_64 kernel-devel-5.14.0-503.35.1.el9_5.x86_64 kernel-modules-core-5.14.0-503.35.1.el9_5.x86_64
Complete!
  1. satisfy third party requirements
subscription-manager repos --enable=rhel-9-for-$arch-appstream-rpms
subscription-manager repos --enable=rhel-9-for-$arch-baseos-rpms
subscription-manager repos --enable=codeready-builder-for-rhel-9-$arch-rpms
dnf install Making sure you're not a bot!
  1. downloaded
  2. install repository
rpm --install nvidia-driver-local-repo-rhel9-570.124.06-1.0-1.x86_64.rpm
package nvidia-driver-local-repo-rhel9-570.124.06-1.0-1.x86_64 is already installed
  1. Driver installation
dnf module install nvidia-driver:latest-dkms
Last metadata expiration check: 0:03:00 ago on Wed 09 Apr 2025 11:36:40 AM EDT.
Installing group/module packages:
nvidia-driver x86_64 3:570.124.06-1.el9 nvidia-driver-local-rhel9-570.124.06 4.0 M
nvidia-settings x86_64 3:570.124.06-1.el9 nvidia-driver-local-rhel9-570.124.06 844 k
nvidia-xconfig x86_64 3:570.124.06-1.el9 nvidia-driver-local-rhel9-570.124.06 93 k
Installing dependencies:
xorg-x11-nvidia x86_64 3:570.124.06-1.el9 nvidia-driver-local-rhel9-570.124.06 2.4 M
Installing module profiles:
nvidia-driver/default
Enabling module streams:
nvidia-driver latest-dkms
Transaction Summary
Install 4 Packages
Total size: 7.3 M
Installed size: 37 M
Is this ok [y/N]: y
Running transaction
Preparing : 1/1
Installing : nvidia-driver-3:570.124.06-1.el9.x86_64 1/4
Running scriptlet: nvidia-driver-3:570.124.06-1.el9.x86_64 1/4
Created symlink /etc/systemd/system/systemd-hibernate.service.wants/nvidia-hibernate.service → /usr/lib/systemd/system/nvidia-hibernate.service.
Created symlink /etc/systemd/system/multi-user.target.wants/nvidia-powerd.service → /usr/lib/systemd/system/nvidia-powerd.service.
Created symlink /etc/systemd/system/systemd-suspend.service.wants/nvidia-resume.service → /usr/lib/systemd/system/nvidia-resume.service.
Created symlink /etc/systemd/system/systemd-hibernate.service.wants/nvidia-resume.service → /usr/lib/systemd/system/nvidia-resume.service.
Created symlink /etc/systemd/system/systemd-suspend-then-hibernate.service.wants/nvidia-resume.service → /usr/lib/systemd/system/nvidia-resume.service.
Created symlink /etc/systemd/system/systemd-suspend.service.wants/nvidia-suspend.service → /usr/lib/systemd/system/nvidia-suspend.service.
Created symlink /etc/systemd/system/systemd-suspend-then-hibernate.service.wants/nvidia-suspend-then-hibernate.service → /usr/lib/systemd/system/nvidia-suspend-then-h
ibernate.service.
Installing : xorg-x11-nvidia-3:570.124.06-1.el9.x86_64
Installing : nvidia-xconfig-3:570.124.06-1.el9.x86_64
Installing : nvidia-settings-3:570.124.06-1.el9.x86_64
Running scriptlet: nvidia-settings-3:570.124.06-1.el9.x86_64
Verifying : nvidia-driver-3:570.124.06-1.el9.x86_64
Verifying : nvidia-settings-3:570.124.06-1.el9.x86_64
Verifying : nvidia-xconfig-3:570.124.06-1.el9.x86_64
Verifying : xorg-x11-nvidia-3:570.124.06-1.el9.x86_64
Installed:
nvidia-driver-3:570.124.06-1.el9.x86_64 nvidia-settings-3:570.124.06-1.el9.x86_64 nvidia-xconfig-3:570.124.06-1.el9.x86_64
Complete!
  1. install compute-only system
dnf install nvidia-driver-cuda kmod-nvidia-latest-dkms
Last metadata expiration check: 0:05:53 ago on Wed 09 Apr 2025 11:36:40 AM EDT.
Package nvidia-driver-cuda-3:570.124.06-1.el9.x86_64 is already installed.
Package kmod-nvidia-latest-dkms-3:570.124.06-1.el9.x86_64 is already installed.
Nothing to do.
Complete!
  1. reboot
nvidia-smi
  1. debug
lsmod | grep nvidia
(reports nothing)
mokutil --sb-state
EFI variables are not supported on this system
(I assume i’m running in BIOS mode so no secure boot.)
modprobe nvidia
modprobe: ERROR: could not insert ‘nvidia’: No such device
dmesg |grep nvidia
[ 4933.185877] nvidia: loading out-of-tree module taints kernel.
[ 4933.185892] nvidia: module license ‘NVIDIA’ taints kernel.
[ 4933.218122] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 4933.391589] nvidia-nvlink: Nvlink Core is being initialized, major device number 237
[ 4933.395237] nvidia-nvlink: Unregistered Nvlink Core, major device number 237
[ 4942.443274] nvidia-nvlink: Nvlink Core is being initialized, major device number 237
[ 4942.445489] nvidia-nvlink: Unregistered Nvlink Core, major device number 237
systemctl status nvidia-powerd
○ nvidia-powerd.service - nvidia-powerd service
Loaded: loaded (/usr/lib/systemd/system/nvidia-powerd.service; enabled; preset: enabled)
Active: inactive (dead) since Wed 2025-04-09 10:27:14 EDT; 1h 24min ago
Duration: 764ms
Main PID: 1449 (code=exited, status=1/FAILURE)
CPU: 16ms
Apr 09 10:27:14 hp1 systemd[1]: Started nvidia-powerd service.
Apr 09 10:27:14 hp1 /usr/bin/nvidia-powerd[1449]: nvidia-powerd version:1.0(build 1)
Apr 09 10:27:14 hp1 /usr/bin/nvidia-powerd[1449]: Allocate client failed 89
Apr 09 10:27:14 hp1 /usr/bin/nvidia-powerd[1449]: Failed to initialize RM Client
Apr 09 10:27:14 hp1 systemd[1]: nvidia-powerd.service: Deactivated successfully.
rpm -qa | grep -i Nvidia
libnvidia-ml-570.124.06-1.el9.x86_64
libnvidia-cfg-570.124.06-1.el9.x86_64
nvidia-driver-cuda-libs-570.124.06-1.el9.x86_64
nvidia-libXNVCtrl-570.124.06-1.el9.x86_64
nvidia-persistenced-570.124.06-1.el9.x86_64
nvidia-modprobe-570.124.06-1.el9.x86_64
nvidia-kmod-common-570.124.06-1.el9.noarch
kmod-nvidia-latest-dkms-570.124.06-1.el9.x86_64
nvidia-driver-libs-570.124.06-1.el9.x86_64
nvidia-driver-cuda-570.124.06-1.el9.x86_64
nvidia-libXNVCtrl-devel-570.124.06-1.el9.x86_64
libnvidia-fbc-570.124.06-1.el9.x86_64
nvidia-driver-570.124.06-1.el9.x86_64
xorg-x11-nvidia-570.124.06-1.el9.x86_64
nvidia-xconfig-570.124.06-1.el9.x86_64
nvidia-settings-570.124.06-1.el9.x86_64
systemctl status nvidia-persistenced
○ nvidia-persistenced.service - NVIDIA Persistence Daemon
Loaded: loaded (/usr/lib/systemd/system/nvidia-persistenced.service; disabled; preset: enabled)
I have the exact same thing happening as well.
please let me know if you were able to get a fix ?
@g.nirta14
If you are using a vGPU download from here
Complete vGPU 18.0 package for RHEL 9.4 including supported guest drivers
it contains the host drivers and guest drivers. It has the exact same driver but its a grid version IDK WHYY they name it the same thing
why not V570.124.06 I dont understand but install
sudo dnf install -y kernel-devel-$(uname -r) kernel-headers-$(uname -r) gcc make dkms acpid libglvnd-glx libglvnd-opengl libglvnd-devel pkgconfig
sudo rpm -iv ./nvidia-linux-grid-570-570.124.06-1.x86_64.rpm
reboot
run nvidia-smi
