High speed ADC boards
For a project I need to sample an analog signal with a rate of 5 Msps and do some processing with it.
I have been searching for a while, but I noticed that there are almost no ready-to-use boards with nearly close sampling rate, aside from a couple of demo or evaluation boards; despite many high speed ADC ICs available. By ready to use, I mean a board which I can directly connect to the Jetson Orin (can also be Jetson Nano) and read the data through USB, SPI, etc.
So, I was wondering, is there a reason why there are no such boards, or am I maybe looking for the wrong thing?
I am completely new to Jetson and this topic, so I would appreciate , if you could point out anything I need to learn more about.
Thank you in advance
Yes, its called so many in the industry have learned there lesson with bringing a new design to market. Not going to burn 6 digits in USD bringing an add-on board to market then have APAC copy the design and sell it for a fraction of the cost of our offering. That is one issue, second is the support of the device tree and 40 pin header. Docs stop short on information intentionally, I will leave it at that. Some other issues exist that contribute to that too.
Thank you for the answer.
So, is there anything you can recommend? Do I have to design a board myself or, for example, is it possible to use an USB oscilloscope as a sampling device and do the processing on Jetson Orin?
As a note, a machine learning model will also be implemented, about which I unfortunately know nothing.
This is only a tiny bit of info on that topic. I don’t think Jetsons do well with hard real-time input of data if they don’t buffer. A lot depends on your need for how much data at which bit depth. Some such boards use i2c, others SPI, so on. Each has a lot to consider, especially if you need a high bit rate. SPI is perhaps one of the better formats for higher bit rates, but it still isn’t a lot for some purposes. You’ll likely never get useful information if you don’t describe what it is you are sampling, e.g., bit depth, bit rate, and how fast you have to interpret this (e.g., maybe it is for later offline examination, and thus all you need to do is store the information and not control a drone with it). USB has a lot more bandwidth, but may lack real-time requirements due to buffering. USB would by far be the easiest, and most likely provide higher bandwidth without a lot of trouble. For most other situations you’d have to start getting into buffering (which might not be possible).
If you happen to have a USB oscilloscope, and if that can feed the time and amplitude at a sample rate you find useful, then it is probably a valid device (though not particularly practical to include in something like a a product you are manufacturing). Feeding that USB oscilloscope to a desktop PC, and then the PC to Jetson is possibly a good choice. Going directly to a Jetson might work, but you’d need one that works on a Jetson, and then you’d still have to worry about buffering and dropping samples. You really need to define your data needs (and timing requirements) before anyone can even come close to answering.
That takes sometime to get up to speed.
SPI is your best option or stream it to the ethernet port. Setup a “bare metal” system to read the a/d then format a packet and send it to the nano for processing or even pre-process some of the signal on the bare metal board.
Many different ways to address this.
Trying to do what you are considering is a challenging task since you will have a bottleneck from cpu to gpu.
Some projects its cheaper in the long run to just buy a piece of off the shelf test equipment.
I see. Thanks to both of you. I will try to get back after learning more.
