HoloLens 1 and 2 support in Omniverse
Does Omniverse support devices like HoloLens 1 and 2 for XR functionality?
I know that Omniverse supports a very wide range of VR headsets. I believe that also includes the Microsoft HoloLens. But let me check as well
We are not officially supporting the HoloLens at this time, but I know it has worked well in the past. I would try to see if you can get it to work. As long as it supports common XR architecture, it should be fine.
Thank you for the response. Please keep us updated if there are any future updates regarding HoloLens connectivity in Omniverse USD Composer. We’ll give it a try based on your suggestions
Yes I will. Thanks and good luck.
