As the title reads, is it currently possible to stream from Omniverse to a unity client application using CloudXR? If yes, are there any resources?
Sorry, I missed this new topic when I wrote my answer on your other post:
Thanks for the debug guide. I found a video regarding streaming from Omniverse to a VR device using Steam VR and tried following the same but using CloudXR instead of steam and also a Unity client application. Here’s the video that I found: [https://www.youtube.com/watch?v=saX-H7S0HgE]
Also, in the Omniverse System requirements guide, For AR, is the AR client application made using Unity? I tried it before but for a VR device and this is what I came across.
Thanks for the info, especially the debug guide. It’s very detailed and will definitely be useful.
Omniverse complicates things.
In the 4.0.1 update to CloudXR documentation, there’s some details on what works with what:
https://docs.nvidia.com/cloudxr-sdk/usr_guide/system_requirements.html#nvidia-omniverse-server-requirements
Omniverse can stream:
- VR with SteamVR (with CloudXR installed)
- VR with CloudXR (directly; no SteamVR or CloudXR install)
- AR with CloudXR (directly; no SteamVR or CloudXR install)
BUT.
- Most Omniverse versions:
- AR with CloudXR only works on iOS devices with the single client available on the App Store, because it uses a non-published CloudXR version (3.3).
- Very recent Omniverse versions:
- AR with CloudXR should work with any correctly compiled/working CloudXR 4.0 AR tablet client
As for Unity: The CloudXR Unity Client Plugin is in beta and only supports Android-based HMDs, that implement the OpenXR API, in VR mode. There is no support for tablet AR.
