I have installed with SDK manager the DRIVE Software 10.0 and DRIVE OS version 5.1.6.1 on the AGX platform.
When I try to go to next step and build the code examples in the host PC in my home area, I get the following errors:
command: $cmake -DCMAKE_BUILD_TYPE=Release …
output: – The C compiler identification is GNU 7.5.0
– The CXX compiler identification is GNU 7.5.0
– Check for working C compiler: /usr/bin/cc
– Check for working C compiler: /usr/bin/cc - works
– Detecting C compiler ABI info
– Detecting C compiler ABI info - done
– Detecting C compile features
– Detecting C compile features - done
– Check for working CXX compiler: /usr/bin/c++
– Check for working CXX compiler: /usr/bin/c++ - works
– Detecting CXX compiler ABI info
– Detecting CXX compiler ABI info - done
– Detecting CXX compile features
– Detecting CXX compile features - done
– Found CUDA: /usr/local/cuda-10.2 (found version “10.2”)
– Found PkgConfig: /usr/bin/pkg-config (found version “0.29.1”)
– Could NOT find EGL (missing: EGL_LIBRARY)
– Looking for pthread.h
– Looking for pthread.h - found
– Performing Test CMAKE_HAVE_LIBC_PTHREAD
– Performing Test CMAKE_HAVE_LIBC_PTHREAD - Failed
– Looking for pthread_create in pthreads
– Looking for pthread_create in pthreads - not found
– Looking for pthread_create in pthread - found
– Found Threads: TRUE
– Building with TRT version and cudnn version 7.5.1.14
– Building GLFW for X11 (static)
– Found X11: /usr/include
– Looking for XOpenDisplay in /usr/lib/x86_64-linux-gnu/libX11.so;/usr/lib/x86_64-linux-gnu/libXext.so
– Looking for XOpenDisplay in /usr/lib/x86_64-linux-gnu/libX11.so;/usr/lib/x86_64-linux-gnu/libXext.so - found
– Looking for gethostbyname
– Looking for gethostbyname - found
– Looking for connect
– Looking for connect - found
– Looking for remove
– Looking for remove - found
– Looking for shmat
– Looking for shmat - found
– Looking for IceConnectionNumber in ICE
– Looking for IceConnectionNumber in ICE - found
– Driveworks Samples install dir: /home/zamanakos/nvidia_samples/build-x86/install
– Driveworks found at: /usr/local/driveworks-2.2/targets/x86_64-Linux
– Found Driveworks
– Configuring done
– Generating done
– Build files have been written to: /home/zamanakos/nvidia_samples/build-x86
and following, in the “$make -j” command, the output is:
[ 58%] Linking CXX shared library libsample_vehicleio_plugin.so
/usr/bin/ld: cannot find -lGL
collect2: error: ld returned 1 exit status
src/vehicleio_plugin/CMakeFiles/sample_vehicleio_plugin.dir/build.make:121: recipe for target ‘src/vehicleio_plugin/libsample_vehicleio_plugin.so’ failed
make[2]: *** [src/vehicleio_plugin/libsample_vehicleio_plugin.so] Error 1
CMakeFiles/Makefile2:3646: recipe for target ‘src/vehicleio_plugin/CMakeFiles/sample_vehicleio_plugin.dir/all’ failed
make[1]: *** [src/vehicleio_plugin/CMakeFiles/sample_vehicleio_plugin.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs…
[ 59%] Linking CXX executable sample_hello_world
src/hello_world/CMakeFiles/sample_hello_world.dir/build.make:121: recipe for target ‘src/hello_world/sample_hello_world’ failed
make[2]: *** [src/hello_world/sample_hello_world] Error 1
CMakeFiles/Makefile2:3024: recipe for target ‘src/hello_world/CMakeFiles/sample_hello_world.dir/all’ failed
make[1]: *** [src/hello_world/CMakeFiles/sample_hello_world.dir/all] Error 2
I am demonstrating only a part of the output from make -j command. Let me know if you need the rest.
I have tried to install the following packages with sudo apt-get install as you suggested here: Nsight Eclipse IDE - ./sample_lane_detection fails
libx11-dev
libxrandr-dev
libxcursor-dev
libxxf86vm-dev
libxinerama-dev
libxi-dev
libglu1-mesa-dev
libglew-dev
libgles2-mesa-dev
but the issue remains.
The host machine is Ubuntu 18.04 with a GeForce GTX 750 installed. The cuda version is the 10.2 as installed from the SDK manager.
Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.5.0.7774
other
Host Machine Version
native Ubuntu 18.04
other
