I run simulation_app as a standalone application like the one below.
https://docs.omniverse.nvidia.com/isaacsim/latest/core_api_tutorials/tutorial_core_hello_world.html#converting-the-example-to-a-standalone-application
I’m trying to add objects with another Python script because I want to add objects dynamically and automatically.
For example, I tried REPL with the below script. But this script cannot generate new object.
from telnetlib import Telnet
import time
def main():
print("Start")
with Telnet("127.0.0.1", 8223) as tn:
print("Connected")
print(tn.read_until(b">>>", timeout=1))
tn.write(b"import omni.kit.commands\n")
print(tn.read_until(b">>>", timeout=0.1))
tn.write(b"omni.kit.commands.execute('CreateMeshPrimWithDefaultXform', prim_type='Cube')\n")
print(tn.read_until(b">>>", timeout=10))
if __name__ == '__main__':
main()
I get below log.
Start
Connected
Telnet(127.0.0.1,8223): recv b'\xff\xfd"\xff\xfb\x03'
Telnet(127.0.0.1,8223): IAC DO 34
Telnet(127.0.0.1,8223): IAC WILL 3
Telnet(127.0.0.1,8223): recv b'\xff\xfa"\x01\x00\xff\xf0\xff\xfb\x01\xff\xfd\x1f\xff\xfd\x18\xff\xfa\x18\x01\xff\xf0'
Telnet(127.0.0.1,8223): IAC 250 not recognized
Telnet(127.0.0.1,8223): IAC 240 not recognized
Telnet(127.0.0.1,8223): IAC WILL 1
Telnet(127.0.0.1,8223): IAC DO 31
Telnet(127.0.0.1,8223): IAC DO 24
b''
Telnet(127.0.0.1,8223): send b'import omni.kit.commands\n'
b''
Telnet(127.0.0.1,8223): send b"omni.kit.commands.execute('CreateMeshPrimWithDefaultXform', prim_type='Cube')\n"
b''
The way with “telnet localhost 8223” and using below commands is worked.
So, the REPL extension is enabled.
How can I add object with another python script?
Thank you.
