I am currently developing a customized pick and place robotics application. While the standalone script runs without issues, I am encountering an error when I incorporate my code into an extension. Specifically, when I try to reset the world using self._world.reset(), I receive the following error:
2023-05-10 14:54:17 [29,214ms] [Error] [omni.physx.tensors.plugin] Failed to create simulation view: no active physics scene found
2023-05-10 14:54:17 [29,215ms] [Error] [omni.ui.python] Exception: Failed to create simulation view backend
The problem also occurs when I use the base extension template and create my world with:
self.my_world = World(stage_units_in_meters=1.0)
and then reset it with:
self.my_world.reset()
This is the whole extension code:
import omni.ext
import omni.ui as ui
from omni.isaac.core import World
# Functions and vars are available to other extension as usual in python: `example.python_ext.some_public_function(x)`
def some_public_function(x: int):
print("[company.hello.world] some_public_function was called with x: ", x)
return x ** x
# Any class derived from `omni.ext.IExt` in top level module (defined in `python.modules` of `extension.toml`) will be
# instantiated when extension gets enabled and `on_startup(ext_id)` will be called. Later when extension gets disabled
# on_shutdown() is called.
class CompanyHelloWorldExtension(omni.ext.IExt):
# ext_id is current extension id. It can be used with extension manager to query additional information, like where
# this extension is located on filesystem.
def on_startup(self, ext_id):
print("[company.hello.world] company hello world startup")
self._count = 0
self._window = ui.Window("My Window", width=300, height=300)
with self._window.frame:
with ui.VStack():
label = ui.Label("")
def on_click():
self._count += 1
label.text = f"count: {self._count}"
def on_reset():
self._count = 0
label.text = "empty"
on_reset()
with ui.HStack():
ui.Button("Add", clicked_fn=on_click)
ui.Button("Reset", clicked_fn=on_reset)
def on_shutdown(self):
print("[company.hello.world] company hello world shutdown")
And this is the error message:
2023-05-12 09:50:22 [527,488ms] [Error] [omni.physx.tensors.plugin] Failed to create simulation view: no active physics scene found
2023-05-12 09:50:22 [527,489ms] [Error] [carb.scripting-python.plugin] Exception: Failed to create simulation view backend
At:
c:\omniverse\pkg\isaac_sim-2022.2.1\kit\extsphysics\omni.physics.tensors-104.2.4-5.1\omni\physics\tensors\impl\api.py(12): create_simulation_view
c:\omniverse\pkg\isaac_sim-2022.2.1\exts\omni.isaac.core\omni\isaac\core\simulation_context\simulation_context.py(389): initialize_physics
c:\omniverse\pkg\isaac_sim-2022.2.1\exts\omni.isaac.core\omni\isaac\core\simulation_context\simulation_context.py(409): reset
c:\omniverse\pkg\isaac_sim-2022.2.1\exts\omni.isaac.core\omni\isaac\core\world\world.py(281): reset
c:\users\user\documents\kit-exts-project\exts\company.hello.world\company\hello\world\extension.py(21): on_startup
c:/omniverse/pkg/isaac_sim-2022.2.1/kit/kernel/py\omni\ext\_impl\_internal.py(147): _startup_ext
c:/omniverse/pkg/isaac_sim-2022.2.1/kit/kernel/py\carb\profiler\__init__.py(81): wrapper
c:/omniverse/pkg/isaac_sim-2022.2.1/kit/kernel/py\omni\ext\_impl\_internal.py(198): startup
c:/omniverse/pkg/isaac_sim-2022.2.1/kit/kernel/py\omni\ext\_impl\_internal.py(285): startup_extension
PythonExtension.cpp::startup()(2): <module>
2023-05-12 09:50:22 [527,490ms] [Error] [omni.ext.plugin] [ext: company.hello.world-1.0.0] Failed to startup python extension.
