Extensions crash isaac sim 4.5.0
Note: For any Isaac Lab topics, please submit your topic to its GitHub repo (GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim) following the instructions provided on Isaac Lab’s Contributing Guidelines (Contribution Guidelines — Isaac Lab Documentation).
Isaac Sim Version
[o] 4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
[o] Windows 10
GPU Information
  • Model: NVIDIA RTX A6000
  • Driver Version:
Topic Description
Detailed Description
(Describe the issue in detail, including what you were trying to do, what you expected to happen, and what actually happened)
Steps to Reproduce
  1. Launch Isaac sim 4.5.0
  2. Click ‘Window-Extensions’
  3. isaac sim has no response
    (Add more steps as needed)
Error Messages
(If applicable, copy and paste any error messages you received)
[79.977s] app ready
2025-05-30 05:54:14 [80,054ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit buffer size 8448000128
2025-05-30 05:54:14 [80,056ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit : valid false, within: false
2025-05-30 05:54:14 [80,057ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit : decrement: 167690, decrement size: 8363520384
2025-05-30 05:54:14 [80,059ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : New limit 8508328 (slope: 503, intercept: 13181056)
2025-05-30 05:54:14 [80,061ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit buffer size 4286378240
2025-05-30 05:54:14 [80,062ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit : valid true, within: true
2025-05-30 05:54:17 [82,168ms] [Warning] [omni.kit.widget.cache_indicator.utils] No library_root key valid path in omniverse.toml
2025-05-30 05:54:17 [82,377ms] [Warning] [omni.kit.widget.cache_indicator.utils] No library_root key valid path in omniverse.toml
2025-05-30 05:54:17 [82,674ms] [Warning] [omni.kit.widget.cache_indicator.utils] No library_root key valid path in omniverse.toml
2025-05-30 05:54:18 [83,843ms] [Warning] [omni.usd-abi.plugin] No setting was found for ‘/rtx-defaults-transient/meshlights/forceDisable’
2025-05-30 05:54:18 [83,980ms] [Warning] [omni.usd-abi.plugin] No setting was found for ‘/rtx-defaults/post/dlss/execMode’
[89.323s] Isaac Sim Full App is loaded.
2025-05-30 05:56:12 [197,514ms] [Warning] [omni.ext.plugin] [ext: opcua] Extensions config ‘extension.toml’ doesn’t exist ‘c:/users/7552918/desktop/omniverse/python/opcua’ or ‘c:/users/7552918/desktop/omniverse/python/opcua/config’
2025-05-30 05:56:12 [197,514ms] [Warning] [omni.ext.plugin] [ext: omniverse-opcua-conveyors-main] Extensions config ‘extension.toml’ doesn’t exist ‘c:/users/7552918/documents/kit/shared/exts/omniverse-opcua-conveyors-main’ or ‘c:/users/7552918/documents/kit/shared/exts/omniverse-opcua-conveyors-main/config’
2025-05-30 05:56:12 [197,514ms] [Warning] [omni.ext.plugin] [ext: 250425_TEST] Extensions config ‘extension.toml’ doesn’t exist ‘c:/users/7552918/desktop/omniverse/python/250425_TEST’ or ‘c:/users/7552918/desktop/omniverse/python/250425_TEST/config’
2025-05-30 05:56:12 [197,514ms] [Warning] [omni.ext.plugin] [ext: python-opcua-master] Extensions config ‘extension.toml’ doesn’t exist ‘c:/users/7552918/desktop/omniverse/python/python-opcua-master’ or ‘c:/users/7552918/desktop/omniverse/python/python-opcua-master/config’
Screenshots or Videos
(If applicable, add screenshots or links to videos that demonstrate the issue)
Additional Information
What I’ve Tried
(Describe any troubleshooting steps you’ve already taken)
Related Issues
(If you’re aware of any related issues or forum posts, please link them here)
Additional Context
(Add any other context about the problem here)
i did turn true to false about
exts.“isaacsim.code_editor.vscode”.carb_logs = false
in ‘exts\isaacsim.code_editor.vscode\config\extension.toml’
who do i fix it
plz help me
Is this issue related to auto-loading the isaacsim.code_editor.vscode extension? Could you please try launching with the --reset-user option to see if that resolves the issue? If it does, please help clarify the steps to reproduce the problem after performing the reset.
OK thanks for your reply, then how to reset with --reset-user option?
I’m usually launch isaac sim by ‘isaac sim,bat’.
@gustjr31321 There are two ways to do so per the official doc:
  • via app selector - you can launch isaac-sim.selector.bat (in the same location as isaac-sim.bat) and input --reset-user into Extra Args field. i believe you only need to do this once to reset the config and shader cache; you can return launching Isaac Sim as you would normally afterwards.
  • via command line - run the .bat with the --reset-user appended at the end as shown below:
Thank you reset option is work well.
Thank you very much. It works well.
