IsaacSim 4.5 completely freezes
Hey!
I have a serious issue with 4.5. I’m setting up a scene with some conveyors and people walking around and everything works great. I then added some new assets from SimReady and when trying to start the simulation again, IsaacSim completely freezes.
The scene was not saved, so I restarted isaacSim, opened the scene without the new assets and it still freezes.
I had the same issue yesterday, which I could only resolve by ‘reinstalling’ 4.5 (unzipping, removing all caches) and recreating my scene, which took me quite some time.
What do you need in a full bug report? This currently blocks my development completely.
Please check for any error messages in the log files at ~/.nvidia-omniverse/logs/Kit//4.5/.
Apologies in advance if I hijack the thread, but I do not know if it is better to open a new topic insofar as I have the exact same issue. I cannot go through the second quickstart tutorial (Quickstart with a Robot — Isaac Sim Documentation) without freezing. This makes IsaacSim unusable. I reinstalled everything once, to no avail. Can someone please help?
Also, I can see some errors in the logs, but I have no idea how to resolve that. The end of the log is as follows:
Blockquote
2025-04-07 11:39:24 [36,296ms] [Info] [rtx.neuraylib.plugin] Stored MdlEntitySnapshot to DB: usd::rtx_scope0::/Franka/panda_hand/geometry/Looks/Aluminum/Shader::::Z73file_3A::home::fom::miniconda3::envs::isa1::lib::Z0Cpython3_2E10::ZC9site_2Dpackages::omni::mdl::core::Base::OmniPBR::OmniPBR((39))
2025-04-07 11:39:24 [36,297ms] [Info] [omni.hydra] Structural change on shade node ‘/Franka/panda_hand/geometry/Looks/Aluminum/Shader’. Initiating database and shader updates.
2025-04-07 11:39:24 [36,297ms] [Info] [omni.hydra] Start creating rendering material for prim ‘/Franka/panda_hand/geometry/Looks/Aluminum/Shader’: usd::rtx_scope0::/Franka/panda_hand/geometry/Looks/Aluminum/Shader::::Z73file_3A::home::fom::miniconda3::envs::isa1::lib::Z0Cpython3_2E10::ZC9site_2Dpackages::omni::mdl::core::Base::OmniPBR::OmniPBR((39))
2025-04-07 11:39:24 [36,297ms] [Info] [omni.hydra] Setting new rendering material for prim ‘/Franka/panda_hand/geometry/Looks/Aluminum/Shader’: usd::rtx_scope0::/Franka/panda_hand/geometry/Looks/Aluminum/Shader::::Z73file_3A::home::fom::miniconda3::envs::isa1::lib::Z0Cpython3_2E10::ZC9site_2Dpackages::omni::mdl::core::Base::OmniPBR::OmniPBR((39))
2025-04-07 11:39:24 [36,297ms] [Info] [omni.hydra] Resolved MdlEntity function overload for prim ‘/Franka/panda_hand/geometry/Looks/PlasticWhite/Shader’ as ‘::Z73file_3A::home::fom::miniconda3::envs::isa1::lib::Z0Cpython3_2E10::ZC9site_2Dpackages::omni::mdl::core::Base::OmniPBR::OmniPBR(color,texture_2d,float,float,float,color,float,float,texture_2d,float,float,texture_2d,float,bool,texture_2d,float,texture_2d,bool,color,texture_2d,texture_2d,float,bool,texture_2d,float,bool,::base::mono_mode,float,float,float,texture_2d,float,texture_2d,bool,bool,bool,bool,int,float2,float,float2,float2,float,float2,float,float,bool)’.
2025-04-07 11:39:24 [36,297ms] [Info] [rtx.neuraylib.plugin] Stored MdlEntitySnapshot to DB: usd::rtx_scope0::/Franka/panda_hand/geometry/Looks/PlasticWhite/Shader::::Z73file_3A::home::fom::miniconda3::envs::isa1::lib::Z0Cpython3_2E10::ZC9site_2Dpackages::omni::mdl::core::Base::OmniPBR::OmniPBR((40))
2025-04-07 11:39:24 [36,297ms] [Info] [omni.hydra] Structural change on shade node ‘/Franka/panda_hand/geometry/Looks/PlasticWhite/Shader’. Initiating database and shader updates.
2025-04-07 11:39:24 [36,297ms] [Info] [omni.hydra] Start creating rendering material for prim ‘/Franka/panda_hand/geometry/Looks/PlasticWhite/Shader’: usd::rtx_scope0::/Franka/panda_hand/geometry/Looks/PlasticWhite/Shader::::Z73file_3A::home::fom::miniconda3::envs::isa1::lib::Z0Cpython3_2E10::ZC9site_2Dpackages::omni::mdl::core::Base::OmniPBR::OmniPBR((40))
2025-04-07 11:39:24 [36,298ms] [Info] [omni.hydra] Setting new rendering material for prim ‘/Franka/panda_hand/geometry/Looks/PlasticWhite/Shader’: usd::rtx_scope0::/Franka/panda_hand/geometry/Looks/PlasticWhite/Shader::::Z73file_3A::home::fom::miniconda3::envs::isa1::lib::Z0Cpython3_2E10::ZC9site_2Dpackages::omni::mdl::core::Base::OmniPBR::OmniPBR((40))
2025-04-07 11:39:24 [36,299ms] [Info] [rtx.materialdb.plugin] Nonvisual material ID (0) was not set because legacy CSV was enabled by setting
2025-04-07 11:39:24 [36,341ms] [Info] [omni.kit.manipulator.prim.usd.data_accessor] Tf.Notice.Register in PrimTransformModel USD
2025-04-07 11:39:24 [36,341ms] [Info] [omni.kit.menu.utils.utils] omni.kit.menu.utils.refresh_menu_items Create
2025-04-07 11:39:24 [36,343ms] [Info] [omni.appwindow.plugin] Created window: width=210,height=114.
2025-04-07 11:39:24 [36,343ms] [Info] [omni.kit.renderer.plugin] Attaching default app window “omni.ui.scene.Widget”
2025-04-07 11:39:24 [36,350ms] [Info] [omni.kit.imgui_renderer.plugin] Creating font texture 1024 x 3240
2025-04-07 11:39:24 [36,394ms] [Info] [omni.kit.menu.utils.utils] omni.kit.menu.utils.refresh_menu_items Edit
2025-04-07 11:39:24 [36,457ms] [Info] [omni.ui.scene] omni.ui.Widget(0xa748c70, frame.name=‘’, frame.identifier=‘’) transitioned to frozen=1
2025-04-07 11:40:40 [112,616ms] [Warning] [carb] Plugin interface for a client: carb.physx.supportui.python was already released.
2025-04-07 11:40:40 [112,619ms] [Warning] [omni.usd] Warning: in SdfPath at line 81 of /builds/omniverse/usd-ci/USD/pxr/usd/sdf/path.cpp – Ill-formed SdfPath <>: syntax error
Blockquote
Blockquote
2025-04-07 11:40:40 [112,624ms] [Info] [omni.physx.plugin] Using CUDA device ordinal 0.
2025-04-07 11:40:40 [112,667ms] [Info] [omni.kit.widget.layers.layer_model] Load sublayers of layer anon:0x76ec9c0045b0:World0.usd.
2025-04-07 11:40:40 [112,667ms] [Info] [omni.kit.widget.layers.layer_model] Load sublayers of layer anon:0x76ec9c00b400:World0-session.usda.
2025-04-07 11:40:40 [112,667ms] [Info] [omni.kit.widget.layers.layer_model] Load sublayers of layer anon:0x2511f730:/articulationsAuthoring.
2025-04-07 11:40:48 [120,254ms] [Info] [omni.kit.menu.utils.utils] omni.kit.menu.utils.refresh_menu_items Create
2025-04-07 11:40:48 [120,263ms] [Info] [omni.kit.menu.utils.utils] omni.kit.menu.utils.refresh_menu_items Edit
2025-04-07 11:40:49 [121,844ms] [Info] [omni.kit.menu.utils.utils] omni.kit.menu.utils.refresh_menu_items Create
2025-04-07 11:40:49 [121,851ms] [Info] [omni.kit.menu.utils.utils] omni.kit.menu.utils.refresh_menu_items Edit
2025-04-07 11:41:07 [138,891ms] [Info] [omni.physx.plugin] Using CUDA device ordinal 0.
2025-04-07 11:41:07 [138,923ms] [Info] [omni.physx.cooking.plugin] ConvexMeshCookingTask: polygon limit reached, resulting convex hull may be suboptimal. Prim
EDIT:
In the terminal that I call IsaacSim from, during loading, I get this:
2025-04-07 11:38:59 [11,257ms] [Error] [gpu.foundation.plugin] No carb::graphics::DescriptorSet for pool 1 on device 0
EDIT2:
The [gpu.foundation.plugin] message reported above is not consistently present.
I have the same problem. The Isaac sim freeze when I load the Franka robot and try to control it. Please fix this problem. Thank you!
@szheng21 Could you please create a new topic with the details of your issue and reference this topic in your post?
@FooTheBar Could you provide the full log? Have you ever enabled the isaacsim.code_editor.vscode extension before encountering this issue?
Hello!
Best regards,
