Shut down when opening Robotics examples
Note: For any Isaac Lab topics, please submit your topic to its GitHub repo (GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim) following the instructions provided on Isaac Lab’s Contributing Guidelines (Contribution Guidelines — Isaac Lab Documentation).
Isaac Sim Version
[v] 4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
[v] Windows 11
Windows 10
GPU Information
  • Model: RTX A4000
  • Driver Version: 572.83
Topic Description
Detailed Description
Example files without robots open and work fine
When opening example files with robots, Isaac Sim stops at 4% loading in the lower right corner
Steps to Reproduce
(Add more steps as needed)
Error Messages
No error Messages because it just freezes
Screenshots or Videos
No screenshots or videos because it just freezes
Additional Information
What I’ve Tried
  1. repeated the same process several times
  2. deleted whole isaacsim folder and re-installed it
Related Issues
None
Additional Context
@Ryuichi_Sakamoto would you be able to provide the full log? you can upload the latest from %userprofile%\.nvidia-omniverse\logs\Kit\Isaac-Sim for further troubleshooting.
kit_20250404_094056.log (760.1 KB)
kit_20250127_201949.log (108.7 KB)
Could you please provide the detailed steps to help us replicate the issue? Which installation method did you use? How to launch the Isaac Sim? Which example did you load?
The installation was done by downloading the compressed file from the NVIDIA homepage and unzipping it directly to the C drive.
The launch was done by running the isaacsim.bat file in the unzipped folder.
If you run any file that contains a robot, Isaacsim will freeze.
If I had to give an example, I would choose franka_URDF.
@Ryuichi_Sakamoto sounded like you went through the workstation installation ( Workstation Installation — Isaac Sim Documentation), correct? if so, i’ve also went through the process but can’t seem to repro the error. i do, however, would like to inquire for a bit more information and note a few things that i’ve observed from looking over the logs:
  • has the Frank_URDF example ever worked for you before or is this the first time you’ve encountered this issue since installing Isaac Sim?
  • Could you take a screengrab of Isaac Sim’s UI?
  • Is this machine being shared? If so, has other users experienced similar issue on that machine?
  • I noticed One Drive is being used based on the log you’ve provided. from my past experience, it has caused issues because One Drive would alter some of the asset paths, have you tried to install Isaac Sim with it disabled? this is may not be relevant since you are only having issues with certain examples, but could be worth looking into.
  • similarly, i saw spaces and special characters (Korean) in documents path from the log. it’s something to avoid using as well but could be situational like the above
  • last but not least, could you also attach the latest log from %userprofile%\.nvidia-omniverse\logs\Kit\Isaac-Sim Full\4.5 as well? the previous path may not have captured the correct session (i was not able to see any explicit error messages)
Thank you for your kind reply
I am gonna reply your answer
      → No, this is first time I’ve encountered this isseus since installing isaacsim
      → I attached a screenshot
      → this machine is not being shared
      → there is no one drive related path at Isaacsim installation.
      → there is no Korean named path at Isaacsim environment
      → Sure, I am gonna re-attached the latest log (I am sorry for my wrong log file)
      kit_20250409_142719.log (1.1 MB)
Thanks in advance
kit_20250410_101616.log (1.1 MB)
I updated my log file (I solved cloud server issues, and it was not a problem)
please check my log file
Please try using the driver versions recommended in Isaac Sim Requirements — Isaac Sim Documentation.
Additionally, please also follow the guidance in this notes:
Note
  • See Technical Requirements for updates.
  • See Linux Troubleshooting to resolve driver installation issues on Linux.
  • We recommend installing the Latest Production Branch Version drivers from the Unix Driver Archive using the .run installer on Linux, if you are on a new GPU or experiencing issues with the current drivers.
  • NVIDIA driver version 535.216.01 or later is recommended when upgrading to Ubuntu 22.04.5 kernel 6.8.0-48-generic or later.
kit_20250410_132246.log (1.3 MB)
I did everything you suggested but it still freezes when I run the robot related example file.
(for example, Robot examples - manipulation - path finding or follow target)
I have attached the relevant logs and screenshots.
Could you try launching Isaac Sim with the --reset-user option?
Thank you for replying.
I’ve soveled this problem by formatting OS
Best Regards
@Ryuichi_Sakamoto Sorry to hear that you’ve already had to format your OS. Have you ever enabled the isaacsim.code_editor.vscode extension before encountering this issue?
Yes I did
is it realted to this issue?
Please refer to Autoloading VS Code Integration breaks URDF import in IsaacSim 4.5.0.
