hallo,
it is possible to cast a 16 byte aligned float* (float array) to a float2* (float2 array)
Thanks for Help
hallo,
Thanks for Help
Yes, you can cast an array of two float to the vector type float2.
E.g; float2 bar= *(float2 *)foo;
but can i cast a array with n values of floats to an array with n/2 values of float2 ???
Can’t see any difference of that and above.
E.g. ((float2 *)floatptr)[idx]
THANK YOU VERY MUCH!
I forget the outside brace…therefore it won’t work…
A.
