How can I connect a Xilinx FPGA to the Jetson AGX Orin? Is there any documentation to illustrate this?
I’m trying to connect a Xilinx FPGA to Jetson AGX Orin. I know the Jetson Orin has PCIe slots.
I wanted to know if anyone was successfully able to establish communication between the two?
Are there any other methods that I can use to connect the two together?
Please check the PCIe section in the design guide Jetson AGX Orin Series Design Guide (including AGX Orin Industrial) Log in | NVIDIA Developer
Connect FPGA as a PCIe end point/root port depending on your use case.
For general guidelines also check Jetson AGX Xavier Series PCIe Endpoint Design Guidelines Application Note Log in | NVIDIA Developer
