How can I display an Nvidia vpi Image in GPU memory?
I’m doing some operations in nvidia vpi image. Then for display I need to download it back to cpu memory.
Is there a way I can display it in vpi Image format itself without bringing it back to cpu?
Here’s my sample code
import numpy as np
from PIL import Image
import cv2
import vpi
# Load input into a vpi.Image
input = vpi.asimage(np.asarray(Image.open('test.png')))
# Using the chosen backend,
with vpi.Backend.CUDA:
    # First convert input to NV12_ER.
    # We're overriding the default backend with CUDA.
    temp = input.convert(vpi.Format.NV12_ER, backend=vpi.Backend.CUDA)
    # Rescale the image using the chosen backend
    temp = temp.rescale((input.width//2, input.height//3))
    # Convert result back to input's format
    output = temp.convert(input.format, backend=vpi.Backend.CUDA)
# Display image
cv2.imshow("output", output.cpu())
cv2.waitKey(0)
VPI doesn’t support display.
But you can try to use it with jetson_utils.
https://elinux.org/Jetson/L4T/TRT_Customized_Example#VPI_with_Jetson-utils
@AastaLLL, in this example also the they’re downloading the image from GPU to CPU (output.cpu())
import numpy as np
import jetson.utils
import vpi
display = jetson.utils.glDisplay()
camera = jetson.utils.gstCamera(1920, 1280, '0')
camera.Open()
while display.IsOpen():
    frame, width, height = camera.CaptureRGBA(zeroCopy=1)
    input = vpi.asimage(np.uint8(jetson.utils.cudaToNumpy(frame)))
        output = input.convert(vpi.Format.U8)
        output = output.box_filter(11, border=vpi.Border.ZERO).convert(vpi.Format.RGB8)
        vpi.clear_cache()
    display.RenderOnce(jetson.utils.cudaFromNumpy(output.cpu()), width, height)
    display.SetTitle("{:s} | {:d}x{:d} | {:.1f} FPS".format("Camera Viewer", width, height, display.GetFPS()))
camera.Close()
