How can I forward the RTSP output to AzureVM?
• DeepStream Version
• TensorRT Version
I am running a sample deepstream python app on JEtson Nano 4gb with jetpack 4.6 and Deepstream 6.0, which output rtsp on localhost, how can I forward it to public ip on my virtual machine(Azure), so the output of the detection app iss accesible via URL?
May be the local rtps server on your host is not needed, you can use rtspclientsink to post the stream to remote VM directly, there should be a rtsp server running on the remote VM.
An example of rtspclientsink as below:
gst-launch-1.0 uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 ! nvvideoconvert ! nvv4l2h264enc ! rtspclientsink location=rtsp://remote-host-ip:8554/test
I am using it with python bindings
server = GstRtspServer.RTSPServer.new()
    server.props.service = "%d" % rtsp_port_num
    server.attach(None)
    factory = GstRtspServer.RTSPMediaFactory.new()
    factory.set_launch(f"( udpsrc name=pay0 port=%d buffer-size=524288 caps=\"application/x-rtp, media=video, clock-rate=90000, encoding-name=(string)%s, payload=96 \" ) rtspclientsink location=rtsp://remote-ip/")
    #factory.set_launch( "( udpsrc name=pay0 port=%d buffer-size=524288 caps=\"application/x-rtp, media=video, clock-rate=90000, encoding-name=(string)%s, payload=96 \" )" % (updsink_port_num, codec))
    factory.set_shared(True)
    server.get_mount_points().add_factory("/rgrt", factory)
is the above example right?
You can use gst-launch-1.0 command to post your stream from your local server to your remote server. If the command pipeline works, you can adapt the python pipeline.
