I use the tools provided by OP-TEE to generate a test EKS image and then use $ sudo ROOTFS_ENC=1 ./tools/kernel_flash/l4t_initrd_flash.sh -i “./disk_enc.key” to flash the Orin Nano NVMe SSD. The flashing is successful and disk encryption is achieved. My question is: how should I quickly and efficiently replicate this in mass production? My current method is to first use dd to copy the NVMe SSD and then perform QSPI internal flashing on the Orin Nano module, but this approach causes errors during device startup, as shown in the attachment. Could you please give me some advice? Thank you!
[com COM4] (2025-11-21_104431) COM4 (Prolific USB-to-Serial Comm Port (COM4)).log (109.9 KB)
