I know Jetson print reboot reason on console when it boot.
then, How can I read reboot reason on linux terminal?
like “$ cat RPM”
If this is tx2, then use the serial console to check
I can see reboot reason on serial console.
but I want to read on kernel terminal block.
I guess there is easy way on L4T
There is something like this which will record the PMIC event. The reset reason should be listed here.
max77620-power max77620-power: Event recorder REG_NVERC : 0x0
