How can I use audio2face and audio2gesture together with a audio streaming player?
For now, you just cannot. Sorry.
to combine them, you need to:
Or you can use A2F headless api to run the A2F part straight from Machinima, but still that does not work with streaming player…
Thanks for your reply, ,,I tried to use the a2f extension in machinima, but the app crashed when I tried to edit the audio2face graph .
But that is sot so easy…
Also, one more time I remind that this solution is not with a realtime streaming audio.
