How can I use DHT22 on Jetson Nano?
I purchased a Jetson Nano developement kit B01 for my project IA.
In fact, i have some problems with using DHT22 sensor for musiring temperature and humidity data. I tried many pins to get Data from the sensor but that doesn’t change anything unfortunately, I still have a reading error, however it works very well with a raspberry card. I’m using the GPIO 216 (pin 7) and i tested this pin to control the LED without problems.
So, can i get more information to resolve this problem and what kind of condition would cause checksum failed.
thank you for your help.
Have refence to below topic.
Thank you for your response.
I read all the reviews but unfortunately still is not solved :/
