Because there is no nano sd module, so I want to use emmc module instead sd module, could you please tell me how can I use it, or some steps to install jupyterlab and jetbot on other modules is preffered
Please check Using Docker Container - JetBot
Or report a bug by creating an issue
Something to keep in mind is that the software flash for any module is separate from installing user applications. User applications (like jupyterlab) will have the same instructions for install and use regardless of being an SD card model or eMMC model (i.e., only flash differs, so if the system is already up and running, you can use the instructions for either model to install…just skip the flash step).
the question is I want to use jetbot on emmc nano module ,but there is no solution ,I know what you said and I installed jupyterlab already, but I can’t install jetbot on emmc module
I’ve never worked with jetbot, so I’m not sure what its instructions are. How is jetbot installed on the SD card version?
Scratch installation is here. (for JetPack 4.4)
It requires tensorflow and pytorch. So I think it cannot install on 16GB emmc. (Because no space left.)
With usb storage and docker, jetbot may work.
But I don’t have jetson nano emmc so can’t be sure.
If this is an eMMC model, then I assume the carrier board is from a third party. Is that correct? If so, then the third party carrier board manufacturer would provide the SD card slot, and they would have the flash software and instructions. This would include how to boot from their carrier board using the SD card. The eMMC model on a dev kit carrier board does not support SD card booting (there might be some unofficial unsupported method, but I am not aware of it). It is trivial though on any model to use an SD card partition on the “/usr/local” mount point, which in turn is where most of that “bulky” software resides, and this would solve the problem without actually booting from an SD card solution (if you know those packages reside somewhere else, then you might mention where since it would offer a clue as to whether there is a simple solution without booting from an external device).
yeah,there no space on 16GB emmc
When you have as much installed as you can without the system not booting, what do you see from this:
sudo du -h -s /usr/local
…and:
df -H -T /
I am thinking that before installing optional content (the content you need, but isn’t actually a boot requirement) is by far located in “/usr/local”. I cannot help with Jetbot since I know so little about it, but the software space issues are almost always related to content in “/usr/local”, and this content can be mounted on a separate device much more easily than booting from another device can be accomplished.
I tried with a SD card with limited capacity + custom JetBot code.
I uninstalled several apt packages to free up space to install JetBot.
Before installation.
After installation.
- Install JetPack 4.6.1 (username: jetbot, no swap)
- Setup wifi. (I don’t check this. but maybe you need wifi)
- run a.sh (First, disable the GUI and reboot. Then run a.sh again.)
a.sh
#!/bin/bash
set -e
# Login password
password='jetbot'
# Record the time this script starts
date
# Get the full dir name of this script
DIR="$( cd "$( dirname "${BASH_SOURCE[0]}" )" >/dev/null 2>&1 && pwd )"
# Keep updating the existing sudo time stamp
sudo -v
while true; do sudo -n true; sleep 120; kill -0 "$$" || exit; done 2>/dev/null &
# No GUI
CHECK_GUI=`readlink -f /etc/systemd/system/default.target`
if [ "$CHECK_GUI" = "/lib/systemd/system/graphical.target" ]; then
# GUI enabled -> disabled
sudo systemctl set-default multi-user.target
sudo reboot
elif [ "$CHECK_GUI" = "/lib/systemd/system/multi-user.target" ]; then
# GUI disabled.
echo "pass"
fi
# Remove apt packages
apt list --installed
sudo apt autoremove -y
sudo apt-get remove -y *xorg
sudo apt-get remove -y lxde* # 133MB
sudo apt-get remove -y unity*
sudo apt-get remove -y python2*
sudo apt-get remove -y lxsession*
sudo apt-get remove -y xserver-xorg*
sudo apt-get remove -y nautilus*
sudo apt-get remove -y gnome-themes*
sudo apt-get remove -y lightdm*
sudo apt-get remove -y libvisionworks*
sudo apt autoremove -y # 38.3MB
sudo rm -rf /etc/apt/sources.list.d/visionworks*
# Enable i2c permissions
echo -e "\e[100m Enable i2c permissions \e[0m"
sudo usermod -aG i2c $USER
# Install apt packages
echo -e "\e[104m Install apt packages \e[0m"
sudo apt-get update
sudo apt-get install -y \
python3-markupsafe \
python3-pip \
libffi-dev
pip3 install -U --no-cache-dir pip
pip3 install -U --no-cache-dir testresources
pip3 install -U --no-cache-dir launchpadlib
pip3 install -U --no-cache-dir setuptools
pip3 install -U --no-cache-dir wheel
pip3 install -U --no-cache-dir packaging
pip3 install -U --no-cache-dir protobuf==3.19.4
pip3 install -U --no-cache-dir numpy==1.19.4
pip3 install -U --no-cache-dir jupyterlab
pip3 install -U --no-cache-dir gdown
PATH="$HOME/.local/bin:$PATH"
df
du -h -d1 | sort -hr
# Jupyter password
jupyter notebook --generate-config
python3 -c "from notebook.auth.security import set_password; set_password('jetbot', '$HOME/.jupyter/jupyter_notebook_config.json')"
# JupyterLab
python3 -m ipykernel install --name python3 --user
# nodejs
# https://github.com/nodesource/distributions/blob/master/README.md
curl
curl -fsSL https://deb.nodesource.com/setup_17.x | sudo -E bash -
sudo apt-get update
nodejs
# nodejs legacy provider
# https://stackoverflow.com/questions/69692842/error-message-error0308010cdigital-envelope-routinesunsupported
# Error: error:0308010C:digital envelope routines::unsupported
export NODE_OPTIONS=--openssl-legacy-provider
# jupyter_clickable_image_widget
jupyter labextension install @jupyter-widgets/jupyterlab-manager
mkdir -p ~/github
cd ~/github
git clone -b jupyterlab-3 https://github.com/naisy/jupyter_clickable_image_widget
cd jupyter_clickable_image_widget
pip3 --no-cache-dir install -e .
jupyter labextension install js
jupyter-lab build
# cleaning
npm cache clean --force
jlpm cache clean
# https://stackoverflow.com/questions/53918811/project-too-large
# ~/github/jupyter_clickable_image_widget/ + ~/.cache/yarn/ = 1GB
# Disable Jupyter autosave
mkdir -p ~/.jupyter/lab/user-settings/\@jupyterlab/docmanager-extension
echo '{
// Document Manager
// @jupyterlab/docmanager-extension:plugin
// Document Manager settings.
// Autosave Documents
// Whether to autosave documents
"autosave": false
> ~/.jupyter/lab/user-settings/\@jupyterlab/docmanager-extension/plugin.jupyterlab-settings
# JetBot
cd ~/github
git clone -b fabo_2022 --depth 1 https://github.com/FaBoPlatform/jetbot
cd ~/github/jetbot
rm -rf .git/ docs/
pip3 install --no-cache-dir -e .
mkdir -p ~/data/Notebooks
cp -r ~/github/jetbot/notebooks ~/data/Notebooks/jetbot
libcairo2-dev \
libgirepository1.0-dev
pip3 install -U --no-cache-dir Jetson.GPIO
pip3 install -U --no-cache-dir PyGObject
# pytorch 1.10.0
cd
wget https://nvidia.box.com/shared/static/fjtbno0vpo676a25cgvuqc1wty0fkkg6.whl -O torch-1.10.0-cp36-cp36m-linux_aarch64.whl
pip3 install --no-cache-dir torch-1.10.0-cp36-cp36m-linux_aarch64.whl
rm torch-1.10.0-cp36-cp36m-linux_aarch64.whl
# torchvision v0.11.1
cd
gdown https://drive.google.com/uc?id=1iMBGTJpmT-4EpG1ZIrMo5-d4PLVyGVYN -O torchvision-0.11.1-cp36-cp36m-linux_aarch64.whl
pip3 install --no-cache-dir torchvision-0.11.1-cp36-cp36m-linux_aarch64.whl
rm torchvision-0.11.1-cp36-cp36m-linux_aarch64.whl
# torch2trt tensorrt8
libopenblas-base \
libopenmpi-dev
export OPENBLAS_CORETYPE=ARMV8
mkdir -p ~/github
cd ~/github
git clone -b jp4.6_tensorrt8 https://github.com/chitoku/torch2trt
cd torch2trt
python3 setup.py install --plugins --user
# models
python3 -c "import torchvision; \
model = torchvision.models.resnet18(pretrained=True)"
# Jupyter launch
export LD_PRELOAD=/usr/lib/aarch64-linux-gnu/libgomp.so.1
jupyter-lab --ip=0.0.0.0 --no-browser --ServerApp.root_dir=/ --LabApp.default_url=/lab?file-browser-path=$HOME/data/Notebooks
Customized part:
・This is the Japanese version.
・Modified to use Jetson.GPIO for i2c bus number detection, so it can work with Jetson Xaiver NX.
・Object Following is rewritten to TF2OD. But you cannot run it. (Important libraries have not been installed. Because no space left.)
・JupyterLab is 3.x. (To check the build, usability)
You can run:
・collision_avoidance: 01, 02, 03, 04
・road_following: 01, 02, 03, 04
When you have finished running the notebook, please shut down Jupyter Kernel to free up memory before proceeding to the next notebook.
