Start with Jetson Nano 16GB emmc module
Author : JTK
Date : 09-26-2022
Subject : Start with Jetson Nano 16GB emmc module
Good day, in this tutorial I’ll explain how to get a Jetson Nano 16GB emmc module working.
This is a way of many. At the end of this tutorial you will have access to Visual studio,
python 3, openCV and Detectnet v2. Hopefully you will succeed and you can enjoy the
power of the Jetson Nano.
Let’s get started
PART 1: Install SKD-M
PART 2: Make some Space!
PART 3: Installing
PART 4: Enjoy.
https://www.waveshare.com/wiki/JETSON-NANO-DEV-KIT#Install_image_on_EMMC
Install Nvidia SDK- manager on a Ubuntu 18.xx PC
That will be your host, not a VM , just a PC.
Install only the Image, flash it…
Install Ubuntu, go to the therminal and go for part 2!
First check the Statics
$ df -h
Open the terminal and let’s go!
$ sudo apt update
$ sudo apt autoremove -y
$ sudo apt clean
$ sudo apt-get remove --purge firefox* thunderbird* libreoffice* man-db libnvinfer-samples cuda-documentation-10-2 cuda-samples-10-2 libvisionworks-samples libopencv-samples -y
$ sudo apt-get autoremove
$ sudo rm -rf /usr/local/cuda/samples \
> /usr/src/cudnn_samples_* \
> /usr/src/tensorrt/data \
> /usr/src/tensorrt/samples \
> /usr/share/visionworks* ~/VisionWorks-SFM*Samples \
> /opt/nvidia/deepstream/deepstream*/samples
$ sudo rm -rf /usr/local/cuda/targets/aarch64-linux/lib/.a \
 > /usr/lib/aarch64-linux-gnu/libcudnn.a \
 > /usr/lib/aarch64-linux-gnu/libnvcaffe_parser*.a \
 > /usr/lib/aarch64-linux-gnu/libnvinfer*.a \
 > /usr/lib/aarch64-linux-gnu/libnvonnxparser*.a \
 > /usr/lib/aarch64-linux-gnu/libnvparsers*.a
$ sudo apt-get purge gnome-shell ubuntu-wallpapers-bionic light-themes chromium-browser* libvisionworks libvisionworks-sfm-dev -y
$ sudo apt-get autoremove -y
$ sudo apt clean -y
$ sudo rm -rf /usr/src/linux-headers-*
$ sudo apt purge cuda-repo-l4t-local libvisionworks-repo -y
$ sudo rm /etc/apt/sources.list.d/cuda*local /etc/apt/sources.list.d/visionworks*repo*
$ sudo apt clean
$ df -h
After this you should be have something like this: 3,9GB USE | 9,2GB FREE
PART 3: Installing
Jetpack;
Jetson-Inference;
Pip3;
OpenCV;
Numpy-Matplotlib;
Visual studio.
Open the terminal and go!
	$ sudo apt install nvidia-jetpack
INSTALL JETSON INFERENCE
$ sudo apt-get update
$ sudo apt-get install git cmake libpython3-dev python3-numpy
$ git clone --recursive https://github.com/dusty-nv/jetson-inference
$ cd jetson-inference
$ mkdir build
$ cd build
I only use Mobilenet v2 and skipped PyTorch
$ cmake ../
$ make -j$(nproc)
$ sudo make install
$ sudo ldconfig
PIP INSTALLL
$ sudo apt update
$ sudo apt install python3-pip
$ pip3 --version
=============================================#IINSTALL OPENCV 4.1.1!!!
$ sudo apt-get install python3-opencv
$ sudo apt-get remove python3-opencv
CHECK version:
$ python3
>>>import cv2
>>>cv2.__version__
INSTALL VISUAL STUDIO , I Just love this IDE, not necessarily necessary
$ cd Downloads
$ sudo apt-get install curl
$ curl -L https://github.com/toolboc/vscode/releases/download/1.32.3/code-oss_1.32.3-arm64.deb -o code-oss_1.32.3-arm64.deb
$ sudo dpkg -i code-oss_1.32.3-arm64.deb
After installing, create a folder where the codes are stored, link to VisualStudio FILE- Link folder. etc.
System settings Visual Studio
Go to EXTENSIONS, Type PYTHON, install PYTHON 3.
Lint is not necessary!
press: CTRL+SHIFT+P
And type in: select interpreter!
select it.
IINSTALL NUMPY,MATHPLOTLIB etc.
$ sudo apt-get install python3-matplotlib
Check the status
$ df -h
 12G Used, 1,9G Avail. 86% full
REBOOT the SYTEM
PART 4: ENJOY!
After the reboot, open an IDE and enjoy.
Have fun with your Jetson Nano!
  • JTK
Nice! Thanks for your sharing with community!
