Can I install deepstreamsdk through sdk manager on jetson-nano-emmc module that has already installed os?
Without entering recovery mode
Can I connect a micro USB to install without logging in on the login screen?
Thank you.
Thank you.
Hi neuezeal,
Yes, you can use sdkmanager to install deepstream.
Please remember unselect “Jetson OS” option to skip flash image and just install “Jetson SDK components” via usb device IP (192.168.55.1) or Ethernet IP.
You can also use below command to install deepstream:
sudo apt-get update
sudo apt-get install deepstream-5.0
