I Can't Flash My Jetson Nano Devoloper Kit
When i try to flash my jetson nano with deepstream and JDKcompenants. I get an error about JDK and deepstream cannot installed. Also sometimes i gets İP connect error but i guess i solved this problem. Firstly i tried open camera but i got V4L2 error so i research this problem and i realised deepstream. Then i wanted to flash again my jetson nano with SDKmanager. But now i can’t flash it. I tried to flash with jetpack version 4.6.6 but it didn’t. Also i have jetracer and i want to connect with that. What should i do
What are JDKcomponents? Is this a third-party develop kit?
You can try to use SDCard to burn Jetson Nano
My jetson nano already has the operating system, so I’m trying to install it via SDK manager. But every time it installs the missing package and there is also a problem with the SD card input. Can I do this with a converter? Also i was wrote JDK but its SDK.
Since you are using Jetson nano, you can only install Jetpack 4.6.
Please make sure that the host is Ubuntu 16.04/18.04. Other OS versions cannot correctly install Jetpack for nano.
In addition, burn the entire system to prevent failure caused by inconsistency between kernel and bsp versions.
