we have choice of VITA and GPT,
How can I use different endpoint from maybe build.nvidia.com or any other openAI compatible model
If you have another openAI compatible model you can run the following:
docker run … -e OPENAI_API_KEY=<OPENAI_API_KEY>
-e VIA_VLM_OPENAI_MODEL_DEPLOYMENT_NAME=gpt-4o
-e VLM_MODEL_TO_USE=openai-compat
You can also load a custom model:
- Mount the directory containing the inference.py file and the optional model files in the
container. - Set the MODEL_PATH env variable to the mount path. MODEL_PATH should point to the
directory containing the inference.py file in the container. - Set VLM_MODEL_TO_USE=custom
ls <MODEL_DIR_ON_HOST>
inference.py
docker run … -v <MODEL_DIR_ON_HOST>:<MODEL_DIR_IN_CONTAINER>
-e MODEL_PATH=<MODEL_DIR_IN_CONTAINER> -e VLM_MODEL_TO_USE=custom …
You can refer to pages 21 and 23 of the VIA DP User Guide for more details.
