It doesn’t work with the regular V100 / P100 drivers
I’m using the IBM and AWS
vGPU drivers are provided by your CSP, in this case AWS:
So it won’t work with t2.xlarge instances?
Are there any free instances available for testing on AWS? Apparently t2.xlarge is not enough and I can’t create G3 or G4dn at my current account level
Yes, CloudXR requires an NVIDIA GPU and works best with G5 instance types. It also can work with G4dn in regions there G5s aren’t available. To use the P3 instance type, you must deploy using the P3 marketplace image that includes the proper driver. This instance type, however, should be avoided as better options are available for streaming XR workloads.
