Has anyone gotten it to work on an AWS g5.2xlarge instance? I installed everything (SteamVR, CloudXR) and enabled all protocols etc. I can’t connect the Quest 2 to it using the latest OVR APK.
Yes. Please see AWS G5 Support
Thanks, I wrote that other ticket :). I installed the G5 drivers successfully and afterwards installed CloudXR server, SteamVR. I was unsuccessful in connecting my Quest 2 to the server though after launching SteamVR and setting the IP address in the txt file.
oh that’s funny – so sorry to have missed that :) I would double check the security group within EC2 to make sure they’re set to allow traffic. This post shows some of them that should be enabled: CloudXR Port Setting on AWS
The security group I have is wide open Inbound and Outbound. I use the same config for G4 as well as G5. Strangely, my G4 instance works fine but G5 fails to connect.
I have attached the logs below if that helps any.
CloudXR Client Log 2022-05-13 15.25.14.txt (3.8 KB)
Streamer Client Log 2022-05-13 15.25.14.txt (205.9 KB)
Hi, has anyone manage to get CloudXR work on AWS G5g instances? Not sure if it is compatible and what is the difference in performance compared to normal G5 instances?
CloudXR will not work on G5g instances, to the best of my knowledge, because CloudXR does not include binaries for ARM Windows. I’m not sure, but my guess is that SteamVR does not provide a build for ARM Windows.
