How do I get the name of the prim?
I found this code to get a list of all objects on the stage.
# Get the stage
default_prim = UsdGeom.Xform.Define(stage, Sdf.Path("/World"))
    stage.SetDefaultPrim(default_prim.GetPrim())
# find the prims with of type UsdGeom.Mesh
prims: List[Usd.Prim] = find_prims_by_type(stage, UsdGeom.Mesh)
prim: Usd.Prim
for prim in prims:
    if prim.GetTypeName() == "Mesh":
        label.text = prim.name
I tried Name with lowercase and uppercase. In my test scene I only have 1 cube.
Does something like prim.GetPrimPath() work? I think that should do the trick.
Regards,
Ales
GetPrimPath did work. I had tried GetPrimPath before, but I kept getting label doesn’t support an arg of type None
What worked was adding str to the result.
if len(str(primPath)) == 0:
(indent) label.text = “Prim Path is Empty”
else:
(indent) label.text = str(primPath)
(This forum doesn’t indent for white space, so I added the indent above)
And the result is /World/Cube, which I can parse out the name.
