I need to generate a system using two separate ethernet cameras and allowing docker modules to connect to the correct one. One camera will be on the RJ-45 connection on the dev board. The other will be on a USB to Ethernet connector off of the USB3.0 connector on the dev board. These are split because of different speeds supported. I am planning to have different addresses on each interface and have DHCP set the addresses for each board, with a different sub-address pool for each interface.
however, I am running into the issue that starting the dhcpd daemon is causing a reset of any changes I make to the pools and resetting the system to only do DHCP on the USB interface to the host.
I have found that there is a camif option which would cover a single camera case. I have not yet found a description of the process to invoke that option.
It does not seem that adding a netplan directory and a .yaml file makes any difference.
The setup is a bit complex and we don’t have experience. This would need other users to provide suggestion.
