Use 2 separate IPs on Jetson
Use Case:
We need to connect two ethernet devices
  1. Radio link 2.4GHz
  2. IP Camera
to create a static interface on jetson nano
As I have made 2 interfaces by editing /etc/network/interfaces
auto eth0
iface eth0 inet static
  address 192.168.2.101
  netmask 255.255.255.0
  gateway 192.168.2.1
auto eth1
iface eth1 inet static
  address 192.168.2.105
  gateway 192.168.2.1
above two interface is ok and running
and i can login using both the interface via ssh
but the camera which is connected via usb to ethernet adaptor is not pinging
We don’t have much experience on this network setup, may other developers help to share experiences if they done something similar.
You have two IPs on 2 separate interfaces (assuming eth1 is your usb to ethernet adapter) inside the same network/netmask and with the same gateway.
You should create a separate network for the second interface.
I imagine when you connected on both interfaces via ssh you did the test by plugin only one ethernet at a time ?
