Ip camera + static ip = problem, need help
I have following setup. Jetson dev board with ip camera (Reolink RLC-410a) connected directly to ethernet port and usb modem (4G). When static ip is set I can get access to camera GUI by typing ip address in browser but in that case internet doesn’t work, but if I have dynamic ip, internet works but camera doesn’t. Is it possible to get everything to work?
This sounds like not an issue limited to jetson nano. I mean if you use the same setup on x64 host, set a static IP which does not go through the gateway would hit the same problem too.
Where is the dhcp server located that can assign the dynamic IP to your host?
Not sure that I understand question. I haven’t set any DHCP server, it was all plug and play up to this point
I have following setup:
Alcatel LinkKey 4G/LTE modem <=> NVidia dev board <= Reolink RLC-410a
Camera have static ip address 192.168.1.60
$ arp -a
? (192.168.1.60) at <incomplete> on usb1
ik40.home (192.168.1.1) at ae:f6:4a:53:a5:2b [ether] on usb1
$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000
    link/ether a2:32:77:97:3e:89 brd ff:ff:ff:ff:ff:ff
3: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether 48:b0:2d:2f:8f:9f brd ff:ff:ff:ff:ff:ff
4: l4tbr0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
    link/ether 4a:de:dc:d8:29:79 brd ff:ff:ff:ff:ff:ff
5: rndis0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast master l4tbr0 state DOWN group default qlen 1000
6: usb0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast master l4tbr0 state DOWN group default qlen 1000
    link/ether 4a:de:dc:d8:29:7b brd ff:ff:ff:ff:ff:ff
7: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
    link/ether 74:d8:3e:44:25:5f brd ff:ff:ff:ff:ff:ff
8: usb1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 1000
    link/ether f6:c1:f2:87:5a:21 brd ff:ff:ff:ff:ff:ff
    inet 192.168.1.102/24 brd 192.168.1.255 scope global dynamic noprefixroute usb1
       valid_lft 6075sec preferred_lft 6075sec
    inet6 fe80::4291:49ab:72d4:75ab/64 scope link noprefixroute
$ ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        ether 48:b0:2d:2f:8f:9f  txqueuelen 1000  (Ethernet)
        RX packets 159  bytes 7314 (7.3 KB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device interrupt 37
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1  (Local Loopback)
        RX packets 1291  bytes 97250 (97.2 KB)
        TX packets 1291  bytes 97250 (97.2 KB)
rndis0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 4a:de:dc:d8:29:79  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
usb0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 4a:de:dc:d8:29:7b  txqueuelen 1000  (Ethernet)
usb1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.1.102  netmask 255.255.255.0  broadcast 192.168.1.255
        inet6 fe80::4291:49ab:72d4:75ab  prefixlen 64  scopeid 0x20<link>
        ether f6:c1:f2:87:5a:21  txqueuelen 1000  (Ethernet)
        RX packets 3084  bytes 1898711 (1.8 MB)
        RX errors 1  dropped 0  overruns 0  frame 1
        TX packets 2808  bytes 551055 (551.0 KB)
I am also not sure which interface is modem and which is IP cam. The only IP from your jetson is usb1: 192.168.1.102, where does this IP come from? Assgined by the modem?
I guess eth0 is camera since is directly connected to ethernet via poe injector, usb1 is modem
Ok, so could you share me when your ethernet is working, what is the ifconfig on your jetson nano? and when ethernet is not working, what is the status on jetson nano?
It sounds like you cannot configure the IP on camera side, right?
Also, what is the interface that you are using to access external ethernet? The usb modem?
ifconfig when i can access to camera gui by typing ip to url but no internet
        inet 192.168.1.60  netmask 255.255.255.0  broadcast 192.168.1.255
        inet6 fe80::4ab0:2dff:fe2f:8f9f  prefixlen 64  scopeid 0x20<link>
        RX packets 36  bytes 33584 (33.5 KB)
        TX packets 133  bytes 10763 (10.7 KB)
        device interrupt 37
        RX packets 668  bytes 53744 (53.7 KB)
        TX packets 668  bytes 53744 (53.7 KB)
        inet 192.168.1.153  netmask 255.255.255.0  broadcast 192.168.1.255
        inet6 fe80::a8e3:d736:293c:88bb  prefixlen 64  scopeid 0x20<link>
        ether c2:1a:20:ab:1a:32  txqueuelen 1000  (Ethernet)
        RX packets 10  bytes 1296 (1.2 KB)
        TX packets 53  bytes 9602 (9.6 KB)
ifconfig when no response from camera GUI but with internet connection
        RX packets 12  bytes 552 (552.0 B)
        TX packets 55  bytes 9199 (9.1 KB)
        device interrupt 37
        RX packets 983  bytes 90422 (90.4 KB)
        TX packets 983  bytes 90422 (90.4 KB)
        inet6 fe80::187d:7eff:fe48:7721  prefixlen 64  scopeid 0x20<link>
        ether 1a:7d:7e:48:77:21  txqueuelen 1000  (Ethernet)
        RX packets 1546  bytes 1219245 (1.2 MB)
        TX packets 1470  bytes 388768 (388.7 KB)
I can use windows machine and set static ip on camera via Reolink client.
Yes, usb modem (Alcatel LinkKey 4g/LTE)
edit: noticed if I quickly open chromium and navigate to camera GUI and some random internet page everything works, and then just stops
I don’t quite understand why changing the camera side configuration will also change the IP to interact with the modem.
Could you share the command you use to change IP and dmesg after the IP on usb1 gets changed?
Can you be more precise what to type/you want, I’m not much of an expert in this?
First, tell us how did you set the ip to make these two cases happen.
By following this guide on stackoverflow
In case where internet was working file was looking like
auto usb1
iface usb1 inet static
  address 192.168.1.102
  gateway 192.168.1.1
in case where i could access to camera
auto eth0
iface eth0 inet static
  address 192.168.1.80
  gateway 192.168.1.1
But when you can access camera, the IP on eth0 is not what you set (192.168.1.80).
And usb1 is not what you set either.
Could you clarify this part?
Could you remove the gateway from your eth0?
So i have to use Reolink client on windows machine to set static IP address on camera as far as I know, it’s not possible to set it up from ubuntu. So this settings
auto eth0
  gateway 192.168.1.1
and I can access to camera
nothing happens when gateway is removed
Err… yes, maybe you have a tool there to set the IP on camera.
But you still not give us an explanation why the IP is 192.168.1.60 but not 192.168.1.80. Is it a typo or it is true the IPs are different?
You said you write 192.168.1.80 to your ubuntu setting, but the result you shared us in previous comment told us it is 192.168.1.60. Also, the IP to access usb modem does not match your config file either.
Not typo, if set as same ip as camera wont work if set to something else, works just set static ip on that interface
so in config is 192.168.1.80 but url is 192.168.1.60 which is true to settings from camera client
What do you mean “set as same ip as camera”? I have no idea about the “url” here either. Could your elaborate it?
Reoling have client that works only on Windows, Mac OS, Android in which you can access to camera settings and fiddle with IP address (default is DHCP), only there you can set IP to be static afaik therefore i set it up to 192.168.1.60.
On Jetson in /etc/network/interfaceshave following settings
auto eth0
  gateway 192.168.1.1
Here if i match ip in settings with ip of camera it doesn’t work, cannot get access to camera, but if i set IP to 192.168.1.80, then i can get access to it.
ok, then where does this ifconfig result come from? The IP here is .1.60 and you told us you can still access the camera.
From what I understand now,
camera → IP 192.168.1.60
Jetson nano interface1 to camera → IP 192.168.1.80
Jetson nano interface2 to usb modem → IP 192.168.1.102
What I cannot understand is why the IP does not follow what you set here. For example, I see usb1 has 192.168.1.153 or eth0 has 192.168.1.60. These do not match your setting.
