Static IP in tx2
Did someone successfully set static IP in tx2? If yes, how did you get it to work?
I want to set the Jetson to have static IP so I can connect to it through ssh with an Ethernet cable in a local network but…
eth0 vanished when I tried to edit the /etc/network/interfaces.d/ to:
auto eth0
iface eth0 inet static
address 192.168.1.150
netmask 255.255.255.0
gateway 192.168.1.2
The same problem in: How to set TX1 to use static IP on ethernet port
The simplest way to set this up is to use an app like “nm-connection-editor” (if you don’t have this, then “sudo apt-get install network-manager-gnome”). Simply look for the MAC address of eth0 (perhaps from “ifconfig”), and then find that in the manager, and tell it to use that address instead of DHCP.
