How to modify the IP address through ssh
I want to set up the network through SSH connection, but I don’t know how to do it.
The hardware is jetson xavier nx
Firmware version is 5.02
Hi pangxie,
Please try following commands:
$ sudo dhclient → enable dhcp client to obtain IP
$ ifconfig → check available network interface
Use ssh command from terminal to connect your board
$ ssh <username>@<inet address>
The current status is dhcp. I want to set it to static ip
You could use ifconfig command or GUI in Jetson Linux to configure static IP
$ sudo ifconfig <interface> <ip>
Ifconfig can only temporarily modify the ip address. I need to change the ip address permanently.
And when I used ifconfig to modify the IP address, I failed.
I want to modify the IP address in the console, not in the GUI
You could use netplan to configure static IP permanently
Netplan static IP on Ubuntu configuration - Linux Tutorials - Learn Linux Configuration
Or refer to following thread to use nm-connection-editor
How can i set static ip in Xavier NX? - #2
The netplan command was not found in the system.
And nm connection editor is a gui tool, which I need to modify in the console.
please intsall netplan with apt
$ sudo apt install netplan.io
