What is the proper way to configure static IPs for the Ethernet ports on a Jetson AGX Xavier using the command line? (My Jetson is headless, so GUI tools are not an option.)
Background:
- My Jetson is running Ubuntu 18.04.
- Contrary to the Ubuntu documentation,
/etc/netplan/99_config.yamldoes not exist. -
etc/network/interfacesdoes not exist either. - I am able set set a static IP on one Ethernet port using the initial setup wizard which runs after flashing, however, I don’t know where this info is being stored so I can configure other ports
Thanks for your help!
