How does NVAPI test stability while using auto oc? (I am trying to bulid an new oc scanner)
Hi, I am trying to build a new auto oc tool for Nvidia GPUs. As we can lock down frequencies and voltages using Nvidia-smi I wanted to know more about how can i test the stability of GPU when set at a particular state. Preferably I want to use the same stress testing that Nvidia uses in the Geforce experience for OC-scanner.
Dear @AANDHI99
Thank you for contacting NVIDIA developer forum.
Our technical team has received your query and we will get back to you after initial investigation.
Thanks,
NVAPI Forum Moderator
Dear @AANDHI99
Thank you for contacting NVIDIA Developer Forum.
As per our technical team, there is no fixed recipe for testing GPU stability when overclocking the GPU. It depends on the GPU usage when overclocked. Our recommended approach is to run some benchmarks after overclocking and assessing stability with those benchmarks. There are several public benchmarking tools available, any public tool can be used for benchmarking.
We hope this resolves your query.
Thank you.
