Added note: nvidia-smi is a PCI tool (a “discrete” dGPU is needed). The GPU in the Jetson is integrated (an iGPU), and so nvidia-smi based applications will not work on a Jetson.
Seems gpu-burn only uses nvidia-smi for monitoring GPU temperature. You may find similar temperature information from tegrastats or from sysfs (PMIC temperature in tegrastats output - #4 by Honey_Patouceul), so you may adapt gpu-burn code and rebuild for Jetson.
Note that there may be other adaptations, for example memory management which is different because iGPU on Jetson shares the same physical memory than CPUs.
Sorry, I do not know of such a case. You would probably have to write a program to do this, or at least port the other nvidia-smi-based tool (which would not be easy).
Followup: As mentioned by @Honey_Patouceul, you can get the temperature with sysfs. If you can find a way to load the GPU, then you probably don’t need the nvidia-smi tools.
I had follow @Honey_Patouceul mentioned.
In fact ,I can get the temperature and other info from jtop,now i remove the source code about nvidia-smi,it’ ok now.
tks.
