How does PX2 refresh the kernel?
- Back up the original kernel binaries’ Image and zImage files.
- Copy the updated Image and zImage files to the directory:
/drive-t186ref-linux/kernel-rt_patches
- Enter this command to update the partition:
./bootburn.sh -b <p3407-t186|p2379c01-t186a|p2379c01-t186b> -u kernel
- To identify the partition name, consult the configuration file used for flashing.
Following the above steps, the kernel has not been replaced. Is the replacement address incorrect?
For Linux:
cd /drive-t186ref-foundation
make -f Makefile.bind PCT=linux BOARD=
./bootburn.sh -b p2379c01-t186a -u kernel
This method does not work either. I saw the path in the cfg file is correct.
./bootburn.sh -b p2379c01-t186a -s -l
It is now only possible to burn the kernel and device tree in this way but it takes 5 minutes to burn.
Is there any way to directly write the kernel or device tree, or can it be the same as TX2, directly SCP or dd?
Dear Calmcar-Bao,
Could you please try to use RCM boot or the “-R” option in bootburn – i.e., “./utils/scripts/bootburn/bootburn.sh -b p2379c01-t186a -R?
This assumes you following the instructions in the System Programming section of the docs to build the kernel and copy to the correct directory
http://docs.nvidia.com/drive/nvvib_docs/index.html#page/NVIDIA%20Vibrante%20Linux%20DPX%20Development%20Guide%2FSystem%20Programming%2Fsys_programming_kernel_toolchain.html%23
./bootburn.sh -b p2379c01-t186a -R
After the burning is successful, the kernel is indeed replaced, but the original kernel is restored after the restart. What’s happening here?
There is a reference to this link, most of the brush parameters are tested, but the strange thing is that
This kind of large-scale brush writing method is still a new kernel after restarting.
The kernel is written separately, and the kernel will restore the original kernel after restarting.
Is it possible to relate to the way I write?
tegrarecovery ab on
tegrareset
tegrarecovery ab off
tegrareset
Is it wrong?
