I have been trying to flash the drive px 2 using the following [url]Autonomous Vehicle Development Platforms | NVIDIA Docs instructions on the nvidia documentation for px 2 but was faced with issues. There are two main methods illustrated and I only need to flash one Ubuntu OS in the PX2.
The first method was using the follow command: ./bootburn.sh -b p2379c01-t186a -d kernel-dtb tegra186-vcm31-p2379-0000-c01-00-base-a-air-cooled.dtb
and bootburn mentioned issues with hypervisor(I will post the full error again later)
The second method used this -
and the flashing process succeeded properly however, upon boot and in the tegra a console(that was flashed) the boot process was stuck at services that were loaded here:
[FAILED] Failed to start Network Service.
See ‘systemctl status systemd-networkd.service’ for details.
[FAILED] Failed to start Login Service.
See ‘systemctl status systemd-logind.service’ for details.
[FAILED] Failed to start Accounts Service.
See ‘systemctl status accounts-daemon.service’ for details.
[FAILED] Failed to start Modem Manager.
See ‘systemctl status ModemManager.service’ for details.
[FAILED] Failed to start Avahi mDNS/DNS-SD Stack.
See ‘systemctl status avahi-daemon.service’ for details.
[FAILED] Failed to start oFono Mobile telephony stack.
See ‘systemctl status ofono.service’ for details.
And from here onwards it doesn’t continue loading and i do not see the terminal console.
Has anyone experienced this problem before during flashing? The usb debug a-a is properly connected, aurix set to run and nothing else is connected to the px 2.
