I have just tried to flash our NVIDIA DRIVE PX 2 AUTOCHAUFFEUR (P2379) to version 5.0.5.0 through DriveInstall_5.0.5.0L_SDK_b96.run.
While the installation of all the packages on the development machine worked. The flashing failed at a certain point with the following error message:
/home/nvidia/NVIDIA/Drive/5050L_SDK///_installer/run_command -c=“chgrp -R nvidia /home/nvidia/NVIDIA/Drive/5050L_SDK//DriveSDK/drive-t186ref-foundation//utils/scripts/bootburn/_temp_dump/” -d=/home/nvidia/NVIDIA/Drive/5050L_SDK///_installer/tmp
1
Failed to flash device. Please check /home/nvidia/NVIDIA/Drive/5050L_SDK/_installer/logs/flash_dual_tegras.log for more details
I have uploaded all the relevant log files here:
https://drive.google.com/open?id=15T4vJ5eGeGZMvTHNCs9Ms_I2-SHbx4bm
When I now boot up the PX 2, I get no screen signal. One of the fans spins up loud for a few seconds, then stops and then repeats the same behaviour. I am able to flash the system again, but it fails at the same point.
I have repeated the flashing procedure 3 times. Restart the host and device between the tries. I always get the same error.
How can I proceed further?
Kind regards,
Christian
