how to downgrade DriveInstall?(Error : Installing Flash Tegra A 5.0.5.0 failed.)
I have now installed DriveInstall 5.0.10.3 version on my Drive PX2 but I need to downgrade to DriveInstall 5.0.5.0bL becuase of Drivework version.
I have already tried to install it several times with DriveInstall 5.0.5.0bL, but the following error will continue to occur while flashing.
Drive PX2 doesn’t turn on after flashing but recovery can be done by attempting Aurix firmware update with 4.02.02 version.
Is it impossible to downgrade DriveInstall?
Is there any function for factory reset on the Drive PX2?
log message
Successfully acquired lock over /var/lock/LCK..bootburn_seq
Successfully acquired lock over /var/lock/LCK..ttyUSB1
Disabling SIGINT <Ctrl+C> temporarily
Setting Tegra-A on hold…cat: /dev/ttyUSB1: Resource temporarily unavailable
Could not execute command “tegrareset a h” on aurix. Log follows,
Bootburn operation unsuccessful
The following tips can help troubleshoot bootburn failures. These are based on
known issues related to setup or missing configuration. If it doesn’t help
resolve the issue, contact module owners with a copy of the full log.
error= error-aurix-command
  • No tips currently available for this failure
I also Attached the screenshot and the log file.
Terminal_Installation.log (151 KB)
Dear stillrunning,
Could you share your Host system details and steps you followed to reproduce this issue? Just to confirm do you see the same issue when you try flashing from another host?
Hi SivaRamaKrishna,
Thank you for you answering.
This is my host system details.
SW
Ubuntu 16.04.5 LTS(Xenial)
nvidia-driver 384.130
CUDA toolkit 9.0(Sept 2017), nvcc v9.0.225
cudnn v7.0.5 for CUDA 9.0
tensorRT 3.0.4
DriveInstall 5.0.5.0bL_SDK_b3
HW
CPU - Intel Core i7-4790K, 3.5GHz
Mainboard - Gigabyte GA-Z97X-UD3H
GPU - Titan Xp(12GB)
Before installing DriveInstall, I Installed the list below.
  • nvidia-driver 384.130
  • CUDA toolkit 9.0(Sept 2017), nvcc v9.0.225
  • cudnn v7.0.5 for CUDA 9.0
  • tensorRT 3.0.4
DriveInstall went through the following steps for install.
  1. I ran DriveInstall and went through the steps until appearing the message below.
    “DriveInstall 5.0.5.0b Linux is about to flash Tesgra A and Tegra B.”
  2. I connected the Drive PX2 to the internet and connected it to the host PC with a debug cable and then powered on.
    I checked the ttyUSB list through the “ls / dev / ttyUSB *” command, but It was nothing problems.
I pressed “Ok” for try to flashing after that, the problem will occur.
There are several Drive PX2s but It need to test in the same environment. that’s why I must need downgrade it.
Dear stillrunning,
Could you tell the host kernel version(uname -a)? Also, do you see success if you try flashing tegras individually?
Hi SivaRamaKrishna,
Thank you for answering.
In ubuntu 14.04, downgrade has just succeeded.
but I will try it again in ubuntu 16.04 and tell you result.
Thank you.
Dear SivaRamaKrishna,
The same error occurred again as shown below.
The host kernel version : Linux stillrunning-host 4.15.0-45-generic #48~16.04.1-Ubuntu SMP Tue Jan 29 18:03:48 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
Flash_dual_tegras.log
Successfully acquired lock over /var/lock/LCK…bootburn_seq
Successfully acquired lock over /var/lock/LCK…ttyUSB1
DriveInstall version of Drive PX2 is 5.0.5.0b(It’s reinstalled by other Host PC which is ubuntu 14.04 ), and the version I was trying to reinstall from the host PC was version .0.5.0b, so this isn’t downgrade issue.
I can solve this problem with a other host PC(Ubuntu 14.04), but I would appreciate it if you could provide solution for this problem to people who face the same problem.
Dear stillrunningf77hc,
The issue could be with linux kernel version. We have seen this flashing issue with our AGX platform as well. W are working for a fix now to support latest kernel versions. Can you downgrade your Linux host kernel to lower version (ex. linux 4.15.0-32) and check installing.
I understood.
Thanks SivaRamaKrishna!
Hello all,
Did the kernel downgrade help to acheive a successful flash ?
Hi aburhanu,
if the meaning of “kernel downgrade” is that using Ubuntu 14.04,
I successed flash with DriveInstall 5.0.5.0bL_SDK_b3.
