We are trying to install DriveInstall5.05.0b on ubuntu16.04 ,but when download the packages in the manager,there are errors that component is missing. We try differnt networks but still have this problem.
Hope your reply.
Best wishes.
Finally it shows Validating packages failed.
Also when click the error link, it asks we to login the website [url]https://partners.nvidia.com/[/url].We don’t know how to do next step.Waiting for your reply.
Dear xiaoxuandong,
Could you please check below link for your topic?
https://docs.nvidia.com/drive/driveinstall_docs/#developertools/mobile/driveinstall/linux/5.0.5.0b/sdk/install.htm%3FTocPath%3D_____3
In network environments that require a proxy server to access the Internet, you can set the http_proxy environment variable by running DriveInstall with following command from a terminal window:
http_proxy=http://username:password@proxy_ip:proxy_port ./DriveInstall_${VERSION}SDK${BUILD}.run
Then DriveInstall will download with this proxy setting.
Note that any special characters (e.g., !,@,#, etc.) in the username or password should be URL encoded.
We had posted 5.0.10 PDK on Devzone.
Could you please use 5.0.10 PDK instead of old version 5.0.5.0b?
Thank you, but I still don’t know what is the username and password should be. My host pc ubuntu can access the Internet and I can surf the Internet.Why I cannot download these components.Hope your reply.
Dear xiaoxuandong,
Could you please help to check if your company is using proxy server or not?
If using proxy server, please refer to above network environment setting.
Because some customers encountered similar issue and fixed this issue with above setting.
And could you please help to check if you can flash PDK with SDK manager?
Thank you. I have solved the above question but meet a new question.
I download the components, follow the instructions to flash Tegra A:
- Unplug all other USB-serial adapters from the host before plugging in the DRIVE PX 2 USB debug cable.
- Make sure to EXIT ALL minicom terminal windows connected to the DRIVE PX 2 device.
- Connect the DRIVE PX 2 device to the Internet with an ethernet cable.
But i shows:Installing Flash Tegra A 5.0.5.0 failed.Return Code: 1.Failed to flash device. Please check /home/audrey/NVIDIA/Drive/5050bL_SDK/_installer/logs/flash_dual_tegras.log for more details.
Then I check the flash_dual_tegras.log:
Successfully acquired lock over /var/lock/LCK..bootburn_seq
Successfully acquired lock over /var/lock/LCK..ttyUSB1
Disabling SIGINT <Ctrl+C> temporarily
Setting Tegra-A on hold...Process CMD (114831) still running. Trying to kill after 5 seconds
/home/audrey/NVIDIA/Drive/5050bL_SDK/DriveSDK/drive-t186ref-foundation/utils/scripts/bootburn/bootburn_lib.sh: line 130: 114829 Killed sudo cat $l_Aurix > $p_FlashFiles/$l_AurixLogFile
Done
Setting Tegra-B on hold...Done
Setting Tegra-A in recovery... Process CMD (114897) still running. Trying to kill after 5 seconds
/home/audrey/NVIDIA/Drive/5050bL_SDK/DriveSDK/drive-t186ref-foundation/utils/scripts/bootburn/bootburn_lib.sh: line 130: 114895 Killed sudo cat $l_Aurix > $p_FlashFiles/$l_AurixLogFile
Process CMD (114927) still running. Trying to kill after 5 seconds
/home/audrey/NVIDIA/Drive/5050bL_SDK/DriveSDK/drive-t186ref-foundation/utils/scripts/bootburn/bootburn_lib.sh: line 130: 114925 Killed sudo cat $l_Aurix > $p_FlashFiles/$l_AurixLogFile
Done
Setting Tegra-B in recovery... Process CMD (115000) still running. Trying to kill after 5 seconds
/home/audrey/NVIDIA/Drive/5050bL_SDK/DriveSDK/drive-t186ref-foundation/utils/scripts/bootburn/bootburn_lib.sh: line 130: 114998 Killed sudo cat $l_Aurix > $p_FlashFiles/$l_AurixLogFile
Process CMD (115055) still running. Trying to kill after 5 seconds
/home/audrey/NVIDIA/Drive/5050bL_SDK/DriveSDK/drive-t186ref-foundation/utils/scripts/bootburn/bootburn_lib.sh: line 130: 115053 Killed sudo cat $l_Aurix > $p_FlashFiles/$l_AurixLogFile
Done
Enabling SIGINT <Ctrl+C>
==> /home/audrey/NVIDIA/Drive/5050bL_SDK/DriveSDK/drive-t186ref-foundation/utils/scripts/bootburn/_temp_dump/TegraALog_xhGjQn2Qgb.txt <==
==> /home/audrey/NVIDIA/Drive/5050bL_SDK/DriveSDK/drive-t186ref-foundation/utils/scripts/bootburn/_temp_dump/TegraBLog_uSSaRy1Re6.txt <==
Target BR_CID: 0x81801001642d98421c00000001fc8100
Target ECID: 0x1642d98421c00000001fc8100
Target BR_CID: 0x81801001642d98421c00000005018380
Target ECID: 0x1642d98421c00000005018380
AdbSerialNum : 1fc81001c000000642d9
Detected prod device type
AdbSerialNum : 50183801c000000642d9
'/home/audrey/NVIDIA/Drive/5050bL_SDK/DriveSDK/drive-t186ref-foundation/utils/scripts/bootburn/../../../firmware/t186/mb1//mb1_recovery_prod.bin' -> '/home/audrey/NVIDIA/Drive/5050bL_SDK/DriveSDK/drive-t186ref-foundation/utils/scripts/bootburn/_temp_dump/_temp_dump_fYOjmvU0Wm/rcm-flash/mb1_recovery.bin'
'/home/audrey/NVIDIA/Drive/5050bL_SDK/DriveSDK/drive-t186ref-foundation/utils/scripts/bootburn/../../../firmware/t186/mb1//mb1_recovery_prod.bin' -> '/home/audrey/NVIDIA/Drive/5050bL_SDK/DriveSDK/drive-t186ref-foundation/utils/scripts/bootburn/_temp_dump/_temp_dump_7GA57hqKW6/rcm-flash/mb1_recovery.bin'
'/home/audrey/NVIDIA/Drive/5050bL_SDK/DriveSDK/drive-t186ref-foundation/utils/scripts/bootburn/../../../firmware/t186/mb1//mb1_prod.bin' -> '/home/audrey/NVIDIA/Drive/5050bL_SDK/DriveSDK/drive-t186ref-foundation/utils/scripts/bootburn/_temp_dump/_temp_dump_fYOjmvU0Wm/rcm-flash/mb1.bin'
'/home/audrey/NVIDIA/Drive/5050bL_SDK/DriveSDK/drive-t186ref-foundation/utils/scripts/bootburn/../../../firmware/t186/mb1//mb1_prod.bin' -> '/home/audrey/NVIDIA/Drive/5050bL_SDK/DriveSDK/drive-t186ref-foundation/utils/scripts/bootburn/_temp_dump/_temp_dump_7GA57hqKW6/rcm-flash/mb1.bin'
Sending MB1
Sending MB1
cat: '/sys//devices/pci0000:00/0000:00:11.0/0000:02:03.0/usb1/1-4/busnum': No such file or directory
cat: '/sys//devices/pci0000:00/0000:00:11.0/0000:02:03.0/usb1/1-4/devnum': No such file or directory
device node not found
Target instance mismatch.
Previous and new port paths do not match
Tool OutPut:
RCM version 0X180001
Boot Rom communication completed
Tool OutPut to stderr:
cat: '/sys//devices/pci0000:00/0000:00:11.0/0000:02:03.0/usb1/1-3/busnum': No such file or directory
cat: '/sys//devices/pci0000:00/0000:00:11.0/0000:02:03.0/usb1/1-3/devnum': No such file or directory
Tool OutPut:
Sending MB1
Tool OutPut:
Sending MB1
Tool OutPut:
Bootburn operation successful
Hope you can help me. Thank you.
Dear xiaoxuandong,
Did you flash Aurix FW before?
And why would you want to install 5.0.5.0 instead of updated PDK 5.0.10?
Because the updated PDK had been fixed bunch of issues. Thanks.
Thank you. I cannot install sdkmanager because I don’t have Nvidia graphics card to install 5.0.10.
I will try to flash Aurix FW.
Hi xiaoxuandong ,
I have the same problem with you when I install the driveinstall5.0.5 on ubuntu16.04, it showed component is missing and Validating packages failed, I want to know how did you solve the problem finally? Thanks a lot!
