hello,
I am setting up the developmet environment on host computer with ubuntu16.04 now,and my target is drive px2, firstly,I download the nvidia sdk manager and install step by step on host computer successfully,I want to know whether I still need to install the DriveInstall? Because when I install the DriveInstall_5.0.5.0bL_SDK_b3.run, some errors occur when downloading some package,showing component is missing and Validating packages failed,I install the DriveInstall in the terminal with the command http_proxy=http://username:password@proxy_ip:proxy_port ./DriveInstall_5.0.5.0bL_SDK_b3.run, hoping for your reply
Dear nli,
Could you let me know if you network environments is that require a proxy server to access the Internet?
If don’t use proxy server, please don’t use http_proxy=http://username:password@proxy_ip:proxy_port
Please just run Install DriveInstall 5.0.5.0b Linux part on https://docs.nvidia.com/drive/driveinstall_docs/#developertools/mobile/driveinstall/linux/5.0.5.0b/sdk/install.htm%3FTocPath%3D_____3
Dear nli,
Would you please delete nvidia folder and sw created by driverinstall and try again? Thanks.
Dear SteveNV,
I have tried,but failed!
Dear SteveNV,
If I installed the package with GUI of SDK Manager successfully, whether I need to install with Driveinstall again?
Dear nli,
If you can flash DrivePX2 board with SDK manger tool, you don’t need Driveinstall.
Could you please try to flash DrivePX2 with SDK manager tool? Thanks.
Dear nli,
Can you access https://developer.nvidia.com/drive/ site with your account and download any material?
Dear SteveNV,
I can login the site above, thank you!
