Software Version
DRIVE OS 6.0.4 SDK
Target Operating System
Linux
Hardware Platform
SDK Manager Version
1.8.2.10409
Host Machine Version
Hello, i have a whole zoo of problems when trying to install and flash with SDK Manger DriveOS 6.0.4 Linux. Precondition with /usr/bin/python is satisfied.
PROBLEM 1: Login to developer.nvidia.com does not work behind corporate proxy
The login via browser works flawlessly, in SDK manager it shows “Login credentials retrieved successfully”, but then it takes long time and finally give the error message “Unable to connect to proxy server” although the proxy configuration is fine.
Therefore i downloaded the relevant files on a different PC (not behind proxy) and copied the files to the target PC which is connected to the orin eval board to continue in offline mode. All following issues are when proceeding in offline mode.
PROBLEM 2: installation of cuda and vulkan packages fails
SDK Manager recognizes the files placed in the download folder (see above) but then installation of some of them fails.
CUDA fails:
14:17:52 ERROR: CUDA on Host - host: E: Unable to locate package cuda-toolkit-11-4
14:17:52 INFO: CUDA on Host - host: [ Package Install Finished with Error ]
14:17:52 INFO: CUDA on Host - host: [host] [ 692.00 KB released. Disk Avail: 58.42 GB ]
14:17:52 INFO: CUDA on Host - host: [ NV_CUDA_HOST_COMP Install took 3s ]
14:17:52 ERROR: CUDA on Host - host: command terminated with error
14:17:52 SUMMARY: CUDA on Host - host: Unable to locate debian package
TensorRT x86 fails:
14:02:43 INFO: TensorRT x86 - host: verifying checksum of /home/tje2abt/workspace/nvidia-driveos-6.0.4-linux-download/nv-tensorrt-repo-ubuntu2004-cuda11.4-trt8.4.11.6-x86-host-ga-20220702_1-1_amd64.deb
14:02:43 INFO: TensorRT x86 - host: Found file /home/tje2abt/workspace/nvidia-driveos-6.0.4-linux-download/nv-tensorrt-repo-ubuntu2004-cuda11.4-trt8.4.11.6-x86-host-ga-20220702_1-1_amd64.deb with correct checksum, skip downloading.
14:17:39 INFO: TensorRT x86 - host: verifying checksum of /home/tje2abt/workspace/nvidia-driveos-6.0.4-linux-download/nv-tensorrt-repo-ubuntu2004-cuda11.4-trt8.4.11.6-x86-host-ga-20220702_1-1_amd64.deb
14:17:39 INFO: TensorRT x86 - host: Found file /home/tje2abt/workspace/nvidia-driveos-6.0.4-linux-download/nv-tensorrt-repo-ubuntu2004-cuda11.4-trt8.4.11.6-x86-host-ga-20220702_1-1_amd64.deb with correct checksum, skip downloading.
14:17:52 SUMMARY: TensorRT x86 - host: Depends on failed component
PROBLEM 3: OS image ready but flashing fails with “file not found”
14:17:48 INFO: Flash DRIVE OS - flash: cd driveinstaller && ./driveinstaller --installtype bindflash --boardtype ES --pdkinstalledpath /home/tje2abt/nvidia/nvidia_sdk/DRIVE_OS_6.0.4_SDK_Linux_DRIVE_AGX_ORIN/DRIVEOS --configjson ./manifests/install_pdk_config/av_orin_p3710_driveos_linux_tegraA_install_config.json --targetuser nvidia --port ${AURIX_PORT:-/dev/ttyACM1} --eula-accepted 1 --consoleout enable --logpath ~/.nvsdkm/
14:17:48 INFO: Flash DRIVE OS - flash: **********************
14:17:48 INFO: Flash DRIVE OS - flash: exec_command: /tmp/tmp_NV_DRIVE_FLASH_DRIVE_COMP.sh
14:17:48 INFO: Flash DRIVE OS - flash: The user `tje2abt' is already a member of `dialout'.
14:17:48 ERROR: Flash DRIVE OS - flash: sed: can't read ./driveinstaller/manifests/install_pdk_config/av_orin_p3710_driveos_linux_tegraA_install_config.json: No such file or directory
14:17:48 INFO: Flash DRIVE OS - flash: [ Component Install Finished with Error ]
14:17:48 INFO: Flash DRIVE OS - flash: [host] [ 20.00 KB used. Disk Avail: 58.42 GB ]
14:17:48 INFO: Flash DRIVE OS - flash: [ NV_DRIVE_FLASH_DRIVE_COMP Install took 1s ]
14:17:48 ERROR: Flash DRIVE OS - flash: command terminated with error
**14:17:48 SUMMARY: Flash DRIVE OS - flash: First Error: No such file or directory**
PROBLEM 4: installation of some packages requires interactive user-input for NV_WORKSPACE
I tried to export NV_WORKSPACE in .bashrc and .profile, but still the interactive request comes up (and of course in SDK manager i cannot type in anything to make it happy).
SDK manager lets a apt-get install producedure hanging waiting for user-input
tje2abt@ABTZ0O1F:~$ ps -aux | grep apt
root 832928 0.0 0.0 37108 5908 ? S 10:13 0:00 sudo -E apt-get install -y --allow-downgrades /home/tje2abt/workspace/nvidia-driveos-6.0.4-linux-download/cuda-repo-ubuntu2004-11-4-local_11.4.17-470.129.06-1_amd64.deb
root 832930 0.1 0.2 97496 75892 ? S 10:13 0:06 apt-get install -y --allow-downgrades /home/tje2abt/workspace/nvidia-driveos-6.0.4-linux-download/cuda-repo-ubuntu2004-11-4-local_11.4.17-470.129.06-1_amd64.deb
tje2abt 852171 0.0 0.0 9036 660 pts/1 S+ 11:37 0:00 grep --color=auto apt
And when i kill this one and run
sudo dpkg --configure -a
It lets me input NV_WORKSPACE interactively and i can continue, but still CUDA is shown as not installed successfully.
SUMMARY:
I tried to cleanup everything with.
#!/bin/bash
sudo rm -rf $NV_WORKSPACE
mkdir $NV_WORKSPACE
rm -rf ~/nvidia/
rm -rf ~/.nvsdkm/
sudo -E apt-get -y --purge remove nv-driveos*
But again, i get in the same situation with problems above.
Attached you find the .nvsdkm folder after several attempts …
.nvsdkm.zip (88.4 KB)
