How Gstreamer uses Python code to implement the gst-launch-1.0 -e function
Jetson AGX
I found a problem when recording a video. If I use the following code, even if I force the program to be interrupted, the recorded video can still be played due to the addition of EOS.
gst-launch-1.0 -e v4l2src ! video/x-raw,width=640,height=480 ! videoconvert ! queue ! timeoverlay ! x264enc key-int-max=10 ! h264parse ! qtmux ! filesink location=video.mov
But when I don’t use the -e parameter, after the recording video is forced to be interrupted, the subsequent video cannot be played, and there are indeed fewer moov atomic files.
How can I change the -e function in python code
python code
test_video_storage.py (4.3 KB)
Comparing the results with or without the -e parameter, with the -e parameter, there is a buffer
If you want to record video, we suggest your use the h264 format to save the video. If you want to implement -e paras in the code, you should catch all the inter msg and send EOS msg by yourself.
I have set the format like this and msg has been set for him, but the parameters like -e don’t know how to affect my writing to the file
test_video_storage.py (5.2 KB)
Can you help me test it? I still can’t play the output video
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one.
1.You cannot set the -e para in deepstream,cause it’s a gst-launch paras. You can refer the source code of gst-launch.c of Gstreamer to impletation it.
https://gstreamer.freedesktop.org/
2.We suggest you save it to h264 format instead of mov if you want to force to stop it.
