Ok, make sure that these files are on your Jetson:
/usr/lib/arm-linux-gnueabihf/gstreamer-0.10/libgstomx.so
/usr/lib/arm-linux-gnueabihf/gstreamer-1.0/libgstomx.so
Here are the elements you should see for 0.10 and 1.0:
ubuntu@tegra-ubuntu:~$ gst-inspect-0.10
subparse: subparse_typefind: srt, sub, mpsub, mdvd, smi, txt, dks
subparse: subparse: Subtitle parser
subparse: ssaparse: SSA Subtitle Parser
equalizer: equalizer-nbands: N Band Equalizer
equalizer: equalizer-3bands: 3 Band Equalizer
equalizer: equalizer-10bands: 10 Band Equalizer
videofilter: gamma: Video gamma correction
videofilter: videobalance: Video balance
videofilter: videoflip: Video flipper
subenc: srtenc: Srt encoder
subenc: webvttenc: WebVTT encoder
faceoverlay: faceoverlay: faceoverlay
flac: flacenc: FLAC audio encoder
flac: flacdec: FLAC audio decoder
flac: flactag: FLAC tagger
sdp: sdpdemux: SDP session setup
gaudieffects: burn: Burn
gaudieffects: chromium: Chromium
gaudieffects: dilate: Dilate
gaudieffects: dodge: Dodge
gaudieffects: exclusion: Exclusion
gaudieffects: solarize: Solarize
gaudieffects: gaussianblur: GaussBlur
isomp4: qtdemux: QuickTime demuxer
isomp4: rtpxqtdepay: RTP packet depayloader
isomp4: qtmux: QuickTime Muxer
isomp4: mp4mux: MP4 Muxer
isomp4: ismlmux: ISML Muxer
isomp4: 3gppmux: 3GPP Muxer
isomp4: gppmux: 3GPP Muxer
isomp4: mj2mux: MJ2 Muxer
isomp4: qtmoovrecover: QT Moov Recover
dvbsuboverlay: dvbsuboverlay: DVB Subtitles Overlay
fsrawconference: fsrawconference: Generic bin
wavenc: wavenc: WAV audio muxer
soup: souphttpsrc: HTTP client source
soup: souphttpclientsink: HTTP client sink
pnm: pnmdec: PNM image decoder
pnm: pnmenc: PNM image encoder
theora: theoradec: Theora video decoder
theora: theoraenc: Theora video encoder
theora: theoraparse: Theora video parser
annodex: cmmlenc: CMML streams encoder
annodex: cmmldec: CMML stream decoder
vorbis: vorbisenc: Vorbis audio encoder
vorbis: vorbisdec: Vorbis audio decoder
vorbis: vorbisparse: VorbisParse
vorbis: vorbistag: VorbisTag
decklink: decklinksrc: Decklink source
decklink: decklinksink: Decklink Sink
mve: mvedemux: MVE Demuxer
mve: mvemux: MVE Multiplexer
rsvg: rsvgoverlay: RSVG overlay
rsvg: rsvgdec: SVG image decoder
flv: flvdemux: FLV Demuxer
flv: flvmux: FLV muxer
gdkpixbuf: gdkpixbufdec: GdkPixbuf image decoder
gdkpixbuf: gdkpixbufsink: GdkPixbuf sink
gdkpixbuf: gdkpixbufscale: GdkPixbuf image scaler
freeverb: freeverb: Stereo positioning
ffmpegcolorspace: ffmpegcolorspace: FFMPEG Colorspace converter
dtsdec: dtsdec: DTS audio decoder
bayer: bayer2rgb: Bayer to RGB decoder for cameras
bayer: rgb2bayer: RGB to Bayer converter
modplug: modplug: ModPlug
audioresample: audioresample: Audio resampler
autoconvert: autoconvert: Select convertor based on caps
autoconvert: autovideoconvert: Select color space convertor based on caps
gio: giosink: GIO sink
gio: giosrc: GIO source
gio: giostreamsink: GIO stream sink
gio: giostreamsrc: GIO stream source
dirac: diracenc: Dirac Encoder
interleave: interleave: Audio interleaver
interleave: deinterleave: Audio deinterleaver
png: pngdec: PNG image decoder
png: pngenc: PNG image encoder
wildmidi: wildmidi: WildMidi
coreelements: capsfilter: CapsFilter
coreelements: fakesrc: Fake Source
coreelements: fakesink: Fake Sink
coreelements: fdsrc: Filedescriptor Source
coreelements: fdsink: Filedescriptor Sink
coreelements: filesrc: File Source
coreelements: funnel: Funnel pipe fitting
coreelements: identity: Identity
coreelements: input-selector: Input selector
coreelements: output-selector: Output selector
coreelements: queue: Queue
coreelements: queue2: Queue 2
coreelements: filesink: File Sink
coreelements: tee: Tee pipe fitting
coreelements: typefind: TypeFind
coreelements: multiqueue: MultiQueue
coreelements: valve: Valve element
videomixer: videomixer: Video mixer
videomixer: videomixer2: Video mixer 2
nvvidconv: nvvidconv: NvVidConv Plugin
vcdsrc: vcdsrc: VCD Source
sdi: sdidemux: SDI Demuxer
sdi: sdimux: SDI Muxer
interlace: interlace: Interlace filter
videoscale: videoscale: Video scaler
soundtouch: pitch: Pitch controller
soundtouch: bpmdetect: BPM Detector
mpegdemux2: mpegpsdemux: The Fluendo MPEG Program Stream Demuxer
mpegdemux2: mpegtsdemux: The Fluendo MPEG Transport stream demuxer
mpegdemux2: mpegtsparse: MPEG transport stream parser
h264parse: legacyh264parse: H264Parse
pango: textoverlay: Text overlay
pango: timeoverlay: Time overlay
pango: clockoverlay: Clock overlay
pango: textrender: Text renderer
mpegpsmux: mpegpsmux: MPEG Program Stream Muxer
zbar: zbar: Barcode detector
videotestsrc: videotestsrc: Video test source
rawparse: videoparse: Video Parse
rawparse: audioparse: Audio Parse
mulaw: mulawenc: Mu Law audio encoder
mulaw: mulawdec: Mu Law audio decoder
cutter: cutter: Audio cutter
ogg: oggdemux: Ogg demuxer
ogg: oggmux: Ogg muxer
ogg: ogmaudioparse: OGM audio stream parser
ogg: ogmvideoparse: OGM video stream parser
ogg: ogmtextparse: OGM text stream parser
ogg: oggparse: Ogg parser
ogg: oggaviparse: Ogg AVI parser
videocrop: videocrop: Crop
videocrop: aspectratiocrop: aspectratiocrop
audiorate: audiorate: Audio rate adjuster
openal: openalsink: Audio sink (OpenAL)
openal: openalsrc: OpenAL src
aiff: aiffparse: AIFF audio demuxer
aiff: aiffmux: AIFF audio muxer
aasink: aasink: ASCII art video sink
curl: curlsink: Curl sink
inter: interaudiosrc: FIXME Long name
inter: interaudiosink: FIXME Long name
inter: intervideosrc: FIXME Long name
inter: intervideosink: FIXME Long name
sndfile: sfsink: Sndfile sink
sndfile: sfsrc: Sndfile source
geometrictransform: circle: circle
geometrictransform: diffuse: diffuse
geometrictransform: kaleidoscope: kaleidoscope
geometrictransform: marble: marble
geometrictransform: pinch: pinch
geometrictransform: rotate: rotate
geometrictransform: sphere: sphere
geometrictransform: twirl: twirl
geometrictransform: waterripple: waterripple
geometrictransform: stretch: stretch
geometrictransform: bulge: bulge
geometrictransform: tunnel: tunnel
geometrictransform: square: square
geometrictransform: mirror: mirror
geometrictransform: fisheye: fisheye
coloreffects: coloreffects: Color Look-up Table filter
coloreffects: chromahold: Chroma hold filter
id3tag: id3mux: ID3 v1 and v2 Muxer
app: appsrc: AppSrc
app: appsink: AppSink
wavparse: wavparse: WAV audio demuxer
mms: mmssrc: MMS streaming source
rtmp: rtmpsrc: RTMP Source
rtmp: rtmpsink: RTMP output sink
asfmux: asfmux: ASF muxer
asfmux: rtpasfpay: RTP ASF payloader
asfmux: asfparse: ASF parser
debug: breakmydata: Break my data
debug: capssetter: CapsSetter
debug: rndbuffersize: Random buffer size
debug: navseek: Seek based on left-right arrows
debug: pushfilesrc: Push File Source
debug: progressreport: Progress report
debug: taginject: TagInject
debug: testsink: Test plugin
debug: capsdebug: Caps debug
debug: cpureport: CPU report
gdp: gdpdepay: GDP Depayloader
gdp: gdppay: GDP Payloader
linsys: linsyssdisrc: SDI video source
linsys: linsyssdisink: SDI video sink
speex: speexenc: Speex audio encoder
speex: speexdec: Speex audio decoder
replaygain: rganalysis: ReplayGain analysis
replaygain: rglimiter: ReplayGain limiter
replaygain: rgvolume: ReplayGain volume
dv: dvdemux: DV system stream demuxer
dv: dvdec: DV video decoder
tta: ttaparse: TTA file parser
tta: ttadec: TTA audio decoder
jack: jackaudiosrc: Audio Source (Jack)
jack: jackaudiosink: Audio Sink (Jack)
video4linux2: v4l2src: Video (video4linux2) Source
video4linux2: v4l2sink: Video (video4linux2) Sink
video4linux2: v4l2radio: Radio (video4linux2) Tuner
mimic: mimenc: Mimic Encoder
mimic: mimdec: Mimic Decoder
videomaxrate: videomaxrate: Video maximum rate adjuster
rtpvp8: rtpvp8depay: RTP VP8 depayloader
rtpvp8: rtpvp8pay: RTP VP8 payloader
cog: cogdownsample: Scale down video by factor of 2
cog: cogcolorspace: YCbCr/RGB format conversion
cog: cogscale: Video scaler
cog: cogcolorconvert: Convert colorspace
cog: coglogoinsert: Overlay image onto video
cog: cogmse: Calculate MSE
icydemux: icydemux: ICY tag demuxer
festival: festival: Festival Text-to-Speech synthesizer
dfbvideosink: dfbvideosink: DirectFB video sink
multipart: multipartdemux: Multipart demuxer
multipart: multipartmux: Multipart muxer
nvjpeg: nvjpegenc: JPEG image encoder
nvjpeg: nvjpegdec: JPEG image decoder
gsettings: gsettingsaudiosink: GSettings audio sink
gsettings: gsettingsaudiosrc: GSettings audio src
gsettings: gsettingsvideosink: GSettings video sink
gsettings: gsettingsvideosrc: GSettings video src
rtp: rtpdepay: Dummy RTP session manager
rtp: rtpac3depay: RTP AC3 depayloader
rtp: rtpac3pay: RTP AC3 audio payloader
rtp: rtpbvdepay: RTP BroadcomVoice depayloader
rtp: rtpbvpay: RTP BV Payloader
rtp: rtpceltdepay: RTP CELT depayloader
rtp: rtpceltpay: RTP CELT payloader
rtp: rtpdvdepay: RTP DV Depayloader
rtp: rtpdvpay: RTP DV Payloader
rtp: rtpgstdepay: GStreamer depayloader
rtp: rtpgstpay: RTP GStreamer payloader
rtp: rtpilbcpay: RTP iLBC Payloader
rtp: rtpilbcdepay: RTP iLBC depayloader
rtp: rtpg722depay: RTP audio depayloader
rtp: rtpg722pay: RTP audio payloader
rtp: rtpg723depay: RTP G.723 depayloader
rtp: rtpg723pay: RTP G.723 payloader
rtp: rtpg726depay: RTP G.726 depayloader
rtp: rtpg726pay: RTP G.726 payloader
rtp: rtpg729depay: RTP G.729 depayloader
rtp: rtpg729pay: RTP G.729 payloader
rtp: rtpgsmdepay: RTP GSM depayloader
rtp: rtpgsmpay: RTP GSM payloader
rtp: rtpamrdepay: RTP AMR depayloader
rtp: rtpamrpay: RTP AMR payloader
rtp: rtppcmadepay: RTP PCMA depayloader
rtp: rtppcmudepay: RTP PCMU depayloader
rtp: rtppcmupay: RTP PCMU payloader
rtp: rtppcmapay: RTP PCMA payloader
rtp: rtpmpadepay: RTP MPEG audio depayloader
rtp: rtpmpapay: RTP MPEG audio payloader
rtp: rtpmparobustdepay: RTP MPEG audio depayloader
rtp: rtpmpvdepay: RTP MPEG video depayloader
rtp: rtpmpvpay: RTP MPEG2 ES video payloader
rtp: rtph263ppay: RTP H263 payloader
rtp: rtph263pdepay: RTP H263 depayloader
rtp: rtph263depay: RTP H263 depayloader
rtp: rtph263pay: RTP H263 packet payloader
rtp: rtph264depay: RTP H264 depayloader
rtp: rtph264pay: RTP H264 payloader
rtp: rtpj2kdepay: RTP JPEG 2000 depayloader
rtp: rtpj2kpay: RTP JPEG 2000 payloader
rtp: rtpjpegdepay: RTP JPEG depayloader
rtp: rtpjpegpay: RTP JPEG payloader
rtp: rtpL16pay: RTP audio payloader
rtp: rtpL16depay: RTP audio depayloader
rtp: asteriskh263: RTP Asterisk H263 depayloader
rtp: rtpmp1sdepay: RTP MPEG1 System Stream depayloader
rtp: rtpmp2tdepay: RTP MPEG Transport Stream depayloader
rtp: rtpmp2tpay: RTP MPEG2 Transport Stream payloader
rtp: rtpmp4vpay: RTP MPEG4 Video payloader
rtp: rtpmp4vdepay: RTP MPEG4 video depayloader
rtp: rtpmp4apay: RTP MPEG4 audio payloader
rtp: rtpmp4adepay: RTP MPEG4 audio depayloader
rtp: rtpmp4gdepay: RTP MPEG4 ES depayloader
rtp: rtpmp4gpay: RTP MPEG4 ES payloader
rtp: rtpqcelpdepay: RTP QCELP depayloader
rtp: rtpqdm2depay: RTP QDM2 depayloader
rtp: rtpsirenpay: RTP Payloader for Siren Audio
rtp: rtpsirendepay: RTP Siren packet depayloader
rtp: rtpspeexpay: RTP Speex payloader
rtp: rtpspeexdepay: RTP Speex depayloader
rtp: rtpsv3vdepay: RTP SVQ3 depayloader
rtp: rtptheoradepay: RTP Theora depayloader
rtp: rtptheorapay: RTP Theora payloader
rtp: rtpvorbisdepay: RTP Vorbis depayloader
rtp: rtpvorbispay: RTP Vorbis depayloader
rtp: rtpvrawdepay: RTP Raw Video depayloader
rtp: rtpvrawpay: RTP Raw Video payloader
monoscope: monoscope: Monoscope
autodetect: autovideosink: Auto video sink
autodetect: autovideosrc: Auto video source
autodetect: autoaudiosink: Auto audio sink
autodetect: autoaudiosrc: Auto audio source
xvid: xvidenc: XviD video encoder
xvid: xviddec: XviD video decoder
videorate: videorate: Video rate adjuster
level: level: Level
removesilence: removesilence: RemoveSilence
ximagesink: ximagesink: Video sink
mpegtsmux: mpegtsmux: MPEG Transport Stream Muxer
audioconvert: audioconvert: Audio converter
voaacenc: voaacenc: AAC audio encoder
cdaudio: cdaudio: CD player
ofa: ofa: OFA
gstsiren: sirendec: Siren Decoder element
gstsiren: sirenenc: Siren Encoder element
omx: nv_omx_mpeg4enc: OpenMAX IL MPEG-4 video encoder
omx: nv_omx_h264enc: OpenMAX IL H.264/AVC video encoder
omx: nv_omx_h263enc: OpenMAX IL H.263 video encoder
omx: nv_omx_vorbisdec: OpenMAX IL Vorbis audio decoder
omx: nv_omx_amrnbenc: OpenMAX IL AMR-NB audio encoder
omx: nv_omx_amrwbenc: OpenMAX IL AMR-WB audio encoder
omx: nv_omx_ilbcenc: OpenMAX IL iLBC audio encoder
omx: nv_omx_jpegenc: OpenMAX IL JPEG image encoder
omx: nv_omx_filereadersrc: OpenMAX IL filereader src element
omx: nv_omx_camera: OpenMAX IL camera src element
omx: nv_omx_mpeg2dec: OpenMAX IL MPEG2 video decoder
omx: nv_omx_mpeg4dec: OpenMAX IL MPEG-4 video decoder
omx: nv_omx_h264dec: OpenMAX IL H.264/AVC video decoder
omx: nv_omx_vp8dec: OpenMAX IL VP8 video decoder
omx: nv_omx_h263dec: OpenMAX IL H.263 video decoder
omx: nv_omx_wmvdec: OpenMAX IL WMV video decoder
omx: nv_omx_jpegdec: OpenMAX IL JPEG decoder
omx: nv_omx_wmadec: OpenMAX IL WMA audio decoder
omx: nv_omx_wmaprodec: OpenMAX IL WMA audio decoder
omx: nv_omx_wmalosslessdec: OpenMAX IL WMA audio decoder
omx: nv_omx_mp3dec: OpenMAX IL MP3 audio decoder
omx: nv_omx_mp2dec: OpenMAX IL MP2 audio decoder
omx: nv_omx_aacdec: OpenMAX IL AAC audio decoder
omx: nv_omx_aacenc: OpenMAX IL AAC audio encoder
omx: nv_omx_vp8enc: OpenMAX IL VP8 video encoder
omx: nv_omx_audiosink: OpenMAX IL audiosink element
omx: nv_gstbin_videosink: OpenMAX IL videosink element
omx: nv_omx_videomixer: OpenMAX IL Nvidia Mixer component
omx: nv_omx_videosink: OpenMAX IL videosink element
omx: nv_omx_hdmi_videosink: OpenMAX IL hdmi videosink element
omx: nv_omx_overlaysink: OpenMAX IL overlaysink element
omx: nv_gl_eglimagesink: OpenMAX IL videosink element
omx: nv_omx_vip: OpenMAX IL vip src element
omx: nv_omx_camera2: Nvidia OMX Camera2
videomeasure: ssim: SSim
videomeasure: measurecollector: Video measure collector
jpegformat: jpegparse: JPEG stream parser
jpegformat: jifmux: JPEG stream muxer
typefindfunctions: video/x-ms-asf: asf, wm, wma, wmv
typefindfunctions: audio/x-musepack: mpc, mpp, mp+
typefindfunctions: audio/x-au: au, snd
typefindfunctions: video/x-msvideo: avi
typefindfunctions: audio/qcelp: qcp
typefindfunctions: video/x-cdxa: dat
typefindfunctions: video/x-vcd: dat
typefindfunctions: audio/x-imelody: imy, ime, imelody
typefindfunctions: audio/midi: mid, midi
typefindfunctions: audio/riff-midi: mid, midi
typefindfunctions: audio/mobile-xmf: mxmf
typefindfunctions: video/x-fli: flc, fli
typefindfunctions: application/x-id3v2: mp3, mp2, mp1, mpga, ogg, flac, tta
typefindfunctions: application/x-id3v1: mp3, mp2, mp1, mpga, ogg, flac, tta
typefindfunctions: application/x-apetag: mp3, ape, mpc, wv
typefindfunctions: audio/x-ttafile: tta
typefindfunctions: audio/x-mod: 669, amf, dsm, gdm, far, imf, it, med, mod, mtm, okt, sam, s3m, stm, stx, ult, xm
typefindfunctions: audio/mpeg: mp3, mp2, mp1, mpga
typefindfunctions: audio/x-ac3: ac3, eac3
typefindfunctions: audio/x-dts: dts
typefindfunctions: audio/x-gsm: gsm
typefindfunctions: video/mpeg-sys: mpe, mpeg, mpg
typefindfunctions: video/mpegts: ts, mts
typefindfunctions: application/ogg: anx, ogg, ogm
typefindfunctions: video/mpeg-elementary: mpv, mpeg, mpg
typefindfunctions: video/mpeg4: m4v
typefindfunctions: video/x-h263: h263, 263
typefindfunctions: video/x-h264: h264, x264, 264
typefindfunctions: video/x-nuv: nuv
typefindfunctions: audio/x-m4a: m4a
typefindfunctions: application/x-3gp: 3gp
typefindfunctions: video/quicktime: mov
typefindfunctions: image/x-quicktime: qif, qtif, qti
typefindfunctions: image/jp2: jp2
typefindfunctions: video/mj2: mj2
typefindfunctions: text/html: htm, html
typefindfunctions: application/vnd.rn-realmedia: ra, ram, rm, rmvb
typefindfunctions: application/x-pn-realaudio: ra, ram, rm, rmvb
typefindfunctions: application/x-shockwave-flash: swf, swfl
typefindfunctions: video/x-flv: flv
typefindfunctions: text/plain: txt
typefindfunctions: text/utf-16: txt
typefindfunctions: text/utf-32: txt
typefindfunctions: text/uri-list: ram
typefindfunctions: application/x-hls: m3u8
typefindfunctions: application/sdp: sdp
typefindfunctions: application/smil: smil
typefindfunctions: application/xml: xml
typefindfunctions: audio/x-wav: wav
typefindfunctions: audio/x-aiff: aiff, aif, aifc
typefindfunctions: audio/x-svx: iff, svx
typefindfunctions: audio/x-paris: paf
typefindfunctions: audio/x-nist: nist
typefindfunctions: audio/x-voc: voc
typefindfunctions: audio/x-sds: sds
typefindfunctions: audio/x-ircam: sf
typefindfunctions: audio/x-w64: w64
typefindfunctions: audio/x-shorten: shn
typefindfunctions: application/x-ape: ape
typefindfunctions: image/jpeg: jpg, jpe, jpeg
typefindfunctions: image/gif: gif
typefindfunctions: image/png: png
typefindfunctions: image/bmp: bmp
typefindfunctions: image/tiff: tif, tiff
typefindfunctions: image/x-portable-pixmap: pnm, ppm, pgm, pbm
typefindfunctions: video/x-matroska: mkv, mka
typefindfunctions: video/webm: webm
typefindfunctions: application/mxf: mxf
typefindfunctions: video/x-mve: mve
typefindfunctions: video/x-dv: dv, dif
typefindfunctions: audio/x-amr-nb-sh: amr
typefindfunctions: audio/x-amr-wb-sh: amr
typefindfunctions: audio/iLBC-sh: ilbc
typefindfunctions: audio/x-sid: sid
typefindfunctions: image/x-xcf: xcf
typefindfunctions: video/x-mng: mng
typefindfunctions: image/x-jng: jng
typefindfunctions: image/x-xpixmap: xpm
typefindfunctions: image/x-sun-raster: ras
typefindfunctions: application/x-bzip: bz2
typefindfunctions: application/x-gzip: gz
typefindfunctions: application/zip: zip
typefindfunctions: application/x-compress: Z
typefindfunctions: subtitle/x-kate: no extensions
typefindfunctions: audio/x-flac: flac
typefindfunctions: audio/x-vorbis: no extensions
typefindfunctions: video/x-theora: no extensions
typefindfunctions: application/x-ogm-video: no extensions
typefindfunctions: application/x-ogm-audio: no extensions
typefindfunctions: application/x-ogm-text: no extensions
typefindfunctions: audio/x-speex: no extensions
typefindfunctions: audio/x-celt: no extensions
typefindfunctions: application/x-ogg-skeleton: no extensions
typefindfunctions: text/x-cmml: no extensions
typefindfunctions: application/x-executable: no extensions
typefindfunctions: audio/aac: aac, adts, adif, loas
typefindfunctions: audio/x-spc: spc
typefindfunctions: audio/x-wavpack: wv, wvp
typefindfunctions: audio/x-wavpack-correction: wvc
typefindfunctions: application/postscript: ps
typefindfunctions: image/svg+xml: svg
typefindfunctions: application/x-rar: rar
typefindfunctions: application/x-tar: tar
typefindfunctions: application/x-ar: a
typefindfunctions: application/x-ms-dos-executable: dll, exe, ocx, sys, scr, msstyles, cpl
typefindfunctions: video/x-dirac: no extensions
typefindfunctions: multipart/x-mixed-replace: no extensions
typefindfunctions: application/x-mmsh: no extensions
typefindfunctions: video/vivo: viv
typefindfunctions: audio/x-nsf: nsf
typefindfunctions: audio/x-gym: gym
typefindfunctions: audio/x-ay: ay
typefindfunctions: audio/x-gbs: gbs
typefindfunctions: audio/x-vgm: vgm
typefindfunctions: audio/x-sap: sap
typefindfunctions: video/x-ivf: ivf
typefindfunctions: audio/x-kss: kss
typefindfunctions: application/pdf: pdf
typefindfunctions: application/msword: doc
typefindfunctions: application/octet-stream: DS_Store
typefindfunctions: image/vnd.adobe.photoshop: psd
typefindfunctions: image/vnd.wap.wbmp: no extensions
typefindfunctions: application/x-yuv4mpeg: y4m
typefindfunctions: image/x-icon: no extensions
typefindfunctions: xdgmime-base: no extensions
typefindfunctions: image/x-degas: no extensions
mpegtsdemux: tsparse: MPEG transport stream parser
mpegtsdemux: tsdemux: MPEG transport stream demuxer
fsvideoanyrate: fsvideoanyrate: Videoanyrate element
decodebin: decodebin: Decoder Bin
rfbsrc: rfbsrc: Rfb source
apetag: apedemux: APE tag demuxer
faad: faad: AAC audio decoder
goom: goom: GOOM: what a GOOM!
uridecodebin: decodebin2: Decoder Bin
uridecodebin: uridecodebin: URI Decoder
cdparanoia: cdparanoiasrc: CD Audio (cdda) Source, Paranoia IV
assrender: assrender: ASS/SSA Render
dtmf: dtmfdetect: DTMF detector element
dtmf: dtmfsrc: DTMF tone generator
dtmf: rtpdtmfsrc: RTP DTMF packet generator
dtmf: rtpdtmfdepay: RTP DTMF packet depayloader
alphacolor: alphacolor: Alpha color filter
alpha: alpha: Alpha filter
rtpmux: rtpmux: RTP muxer
rtpmux: rtpdtmfmux: RTP muxer
fsrtcpfilter: fsrtcpfilter: RTCP Filter element
cairo: cairotextoverlay: Text overlay
cairo: cairotimeoverlay: Time overlay
cairo: cairooverlay: Cairo overlay
cairo: cairorender: Cairo encoder
colorspace: colorspace: Colorspace converter
camerabin2: viewfinderbin: Viewfinder Bin
camerabin2: wrappercamerabinsrc: V4l2 camera src element for camerabin
camerabin2: camerabin2: CameraBin2
gmedec: gmedec: Gaming console music file decoder
gsm: gsmenc: GSM audio encoder
gsm: gsmdec: GSM audio decoder
dataurisrc: dataurisrc: data: URI source element
volume: volume: Volume
videofiltersbad: scenechange: Scene change detector
videofiltersbad: zebrastripe: Zebra stripe overlay
voamrwbenc: voamrwbenc: AMR-WB audio encoder
debugutilsbad: checksumsink: Checksum sink
debugutilsbad: fpsdisplaysink: Measure and show framerate on videosink
debugutilsbad: chopmydata: FIXME
debugutilsbad: compare: Compare buffers
debugutilsbad: debugspy: DebugSpy
coreindexers: memindex: A index that stores entries in memory
coreindexers: fileindex: A index that stores entries in file
spandsp: spanplc: SpanDSP PLC
avi: avidemux: Avi demuxer
avi: avimux: Avi muxer
avi: avisubtitle: Avi subtitle parser
schro: schrodec: Dirac Decoder
schro: schroenc: Dirac Encoder
fbdevsink: fbdevsink: fbdev video sink
speed: speed: Speed
kate: katedec: Kate stream text decoder
kate: kateenc: Kate stream encoder
kate: kateparse: Kate stream parser
kate: katetag: Kate stream tagger
cdxaparse: cdxaparse: (S)VCD parser
cdxaparse: vcdparse: (S)VCD stream parser
dvb: dvbsrc: DVB Source
dvb: dvbbasebin: DVB bin
bz2: bz2enc: BZ2 encoder
bz2: bz2dec: BZ2 decoder
gstrtpmanager: gstrtpbin: RTP Bin
gstrtpmanager: gstrtpjitterbuffer: RTP packet jitter-buffer
gstrtpmanager: gstrtpptdemux: RTP Demux
gstrtpmanager: gstrtpsession: RTP Session
gstrtpmanager: gstrtpssrcdemux: RTP SSRC Demux
flite: flitetestsrc: Flite speech test source
adder: adder: Adder
audiovisualizers: spacescope: Stereo visualizer
audiovisualizers: spectrascope: Frequency spectrum scope
audiovisualizers: synaescope: Synaescope
audiovisualizers: wavescope: Waveform oscilloscope
nuvdemux: nuvdemux: Nuv demuxer
rtsp: rtspsrc: RTSP packet receiver
rtsp: rtpdec: RTP Decoder
fieldanalysis: fieldanalysis: Video field analysis
vmnc: vmncdec: VMnc video decoder
shout2send: shout2send: Icecast network sink
ossaudio: ossmixer: OSS Mixer
ossaudio: osssrc: Audio Source (OSS)
ossaudio: osssink: Audio Sink (OSS)
hdvparse: hdvparse: HDVParser
mxf: mxfdemux: MXF Demuxer
mxf: mxfmux: MXF muxer
imagefreeze: imagefreeze: Still frame stream generator
legacyresample: legacyresample: Audio scaler
navigationtest: navigationtest: Video navigation test
stereo: stereo: Stereo effect
liveadder: liveadder: Live Adder element
id3demux: id3demux: ID3 tag demuxer
smooth: smooth: Smooth effect
adpcmenc: adpcmenc: ADPCM encoder
wavpack: wavpackparse: Wavpack parser
wavpack: wavpackdec: Wavpack audio decoder
wavpack: wavpackenc: Wavpack audio encoder
fragmented: hlsdemux: HLS Demuxer
y4menc: y4menc: YUV4MPEG video encoder
jpeg: jpegenc: JPEG image encoder
jpeg: jpegdec: JPEG image decoder
jpeg: smokeenc: Smoke video encoder
jpeg: smokedec: Smoke video decoder
dvdspu: dvdspu: Sub-picture Overlay
shapewipe: shapewipe: Shape Wipe transition filter
cacasink: cacasink: A colored ASCII art video sink
segmentclip: audiosegmentclip: Audio buffer segment clipper
segmentclip: videosegmentclip: Video buffer segment clipper
udp: udpsink: UDP packet sender
udp: multiudpsink: UDP packet sender
udp: dynudpsink: UDP packet sender
udp: udpsrc: UDP packet receiver
scaletempo: scaletempo: Scaletempo
goom2k1: goom2k1: GOOM: what a GOOM! 2k1 edition
musepack: musepackdec: Musepack decoder
audioparsers: aacparse: AAC audio stream parser
audioparsers: amrparse: AMR audio stream parser
audioparsers: ac3parse: AC3 audio stream parser
audioparsers: dcaparse: DTS Coherent Acoustics audio stream parser
audioparsers: flacparse: FLAC audio parser
audioparsers: mpegaudioparse: MPEG1 Audio Parser
patchdetect: patchdetect: Color Patch Detector
playback: playbin: Player Bin
playback: playbin2: Player Bin 2
playback: playsink: Player Sink
playback: subtitleoverlay: Subtitle Overlay
videoparsersbad: h263parse: H.263 parser
videoparsersbad: h264parse: H.264 parser
videoparsersbad: diracparse: Dirac parser
videoparsersbad: mpegvideoparse: MPEG video elementary stream parser
videoparsersbad: mpeg4videoparse: MPEG 4 video elementary stream parser
dc1394: dc1394src: 1394 IIDC Video Source
fsfunnel: fsfunnel: Farstream Funnel pipe fitting
taglib: id3v2mux: TagLib-based ID3v2 Muxer
taglib: apev2mux: TagLib-based APEv2 Muxer
flxdec: flxdec: FLX video decoder
fsrtpconference: fsrtpconference: Farstream RTP Conference
spectrum: spectrum: Spectrum analyzer
shm: shmsrc: Shared Memory Source
shm: shmsink: Shared Memory Sink
oss4: oss4sink: OSS v4 Audio Sink
oss4: oss4src: OSS v4 Audio Source
oss4: oss4mixer: OSS v4 Audio Mixer
pcapparse: pcapparse: PCapParse
pcapparse: irtspparse: IRTSPParse
audiotestsrc: audiotestsrc: Audio test source
camerabin: camerabin: Camera Bin
adpcmdec: adpcmdec: ADPCM decoder
dccp: dccpclientsrc: DCCP client source
dccp: dccpserversink: DCCP server sink
dccp: dccpclientsink: DCCP client sink
dccp: dccpserversrc: DCCP server source
audiofx: audiopanorama: Stereo positioning
audiofx: audioinvert: Audio inversion
audiofx: audiokaraoke: AudioKaraoke
audiofx: audioamplify: Audio amplifier
audiofx: audiodynamic: Dynamic range controller
audiofx: audiocheblimit: Low pass & high pass filter
audiofx: audiochebband: Band pass & band reject filter
audiofx: audioiirfilter: Audio IIR filter
audiofx: audiowsinclimit: Low pass & high pass filter
audiofx: audiowsincband: Band pass & band reject filter
audiofx: audiofirfilter: Audio FIR filter
audiofx: audioecho: Audio echo
opus: opusenc: Opus audio encoder
opus: opusdec: Opus audio decoder
opus: opusparse: Opus audio parser
opus: rtpopusdepay: RTP Opus packet depayloader
opus: rtpopuspay: RTP Opus payloader
smpte: smpte: SMPTE transitions
smpte: smptealpha: SMPTE transitions
alsa: alsamixer: Alsa mixer
alsa: alsasrc: Audio source (ALSA)
alsa: alsasink: Audio sink (ALSA)
ximagesrc: ximagesrc: Ximage video source
ivfparse: ivfparse: IVF parser
fsmsnconference: fsmsncamsendconference: Farstream MSN Sending Conference
fsmsnconference: fsmsncamrecvconference: Farstream MSN Reception Conference
multifile: multifilesrc: Multi-File Source
multifile: multifilesink: Multi-File Sink
multifile: splitfilesrc: Split-File Source
teletext: teletextdec: Teletext decoder
jp2k: jp2kdec: Jasper JPEG2000 image decoder
jp2k: jp2kenc: Jasper JPEG2000 image encoder
mpegvideoparse: legacympegvideoparse: MPEG video elementary stream parser
1394: dv1394src: Firewire (1394) DV video source
1394: hdv1394src: Firewire (1394) HDV video source
freeze: freeze: Stream freezer
pulseaudio: pulsesink: PulseAudio Audio Sink
pulseaudio: pulsesrc: PulseAudio Audio Source
pulseaudio: pulseaudiosink: Bin wrapping pulsesink
pulseaudio: pulsemixer: PulseAudio Mixer
matroska: matroskademux: Matroska demuxer
matroska: matroskaparse: Matroska parser
matroska: matroskamux: Matroska muxer
matroska: webmmux: WebM muxer
videobox: videobox: Video box filter
nice: nicesrc: ICE source
nice: nicesink: ICE sink
encoding: encodebin: Encoder Bin
xvimagesink: xvimagesink: Video sink
jp2kdecimator: jp2kdecimator: JPEG2000 decimator
tcp: tcpclientsink: TCP client sink
tcp: tcpclientsrc: TCP client source
tcp: tcpserversink: TCP server sink
tcp: tcpserversrc: TCP server source
tcp: multifdsink: Multi filedescriptor sink
alaw: alawenc: A Law audio encoder
alaw: alawdec: A Law audio decoder
y4mdec: y4mdec: YUV4MPEG demuxer/decoder
libvisual: libvisual_bumpscope: libvisual Bumpscope plugin plugin v.0.0.1
libvisual: libvisual_corona: libvisual libvisual corona plugin plugin v.0.1
libvisual: libvisual_infinite: libvisual infinite plugin plugin v.0.1
libvisual: libvisual_jakdaw: libvisual Jakdaw plugin plugin v.0.0.1
libvisual: libvisual_jess: libvisual jess plugin plugin v.0.1
libvisual: libvisual_lv_analyzer: libvisual libvisual analyzer plugin v.1.0
libvisual: libvisual_lv_scope: libvisual libvisual scope plugin v.0.1
libvisual: libvisual_oinksie: libvisual oinksie plugin plugin v.0.1
effectv: edgetv: EdgeTV effect
effectv: agingtv: AgingTV effect
effectv: dicetv: DiceTV effect
effectv: warptv: WarpTV effect
effectv: shagadelictv: ShagadelicTV
effectv: vertigotv: VertigoTV effect
effectv: revtv: RevTV effect
effectv: quarktv: QuarkTV effect
effectv: optv: OpTV effect
effectv: radioactv: RadioacTV effect
effectv: streaktv: StreakTV effect
effectv: rippletv: RippleTV effect
efence: efence: Electric Fence
vp8: vp8dec: On2 VP8 Decoder
vp8: vp8enc: On2 VP8 Encoder
resindvd: rsndvdbin: rsndvdbin
nsf: nsfdec: Nsf decoder
videosignal: videoanalyse: Video analyser
videosignal: videodetect: Video detecter
videosignal: videomark: Video marker
auparse: auparse: AU audio demuxer
deinterlace: deinterlace: Deinterlacer
apexsink: apexsink: Apple AirPort Express Audio Sink
staticelements: bin: Generic bin
staticelements: pipeline: Pipeline object
Total count: 226 plugins, 713 features
ubuntu@tegra-ubuntu:~$ gst-inspect-1.0
videoconvert: videoconvert: Colorspace converter
videofilter: videomedian: Median effect
gdkpixbuf: gdkpixbufoverlay: GdkPixbuf Overlay
videomixer: videomixer: Video mixer 2
eglglessink: nveglglessink: EGL/GLES vout Sink
app: appsrc: AppSrc
vpx: vp9enc: On2 VP9 Encoder
vpx: vp9dec: On2 VP9 Decoder
vpx: vp8enc: On2 VP8 Encoder
vpx: vp8dec: On2 VP8 Decoder
nvcamera: nvtee: NvTee
nvcamera: nvcamerasrc: Nvidia Camera Source
rtp: rtpvp8pay: RTP VP8 payloader
rtp: rtpvp8depay: RTP VP8 depayloader
rtp: rtpsbcpay: RTP packet payloader
rtp: rtpsbcdepay: RTP SBC audio depayloader
rtp: rtpL24depay: RTP audio depayloader
rtp: rtpL24pay: RTP audio payloader
clutter: autocluttersink: Auto Clutter Sink
clutter: cluttersink: Clutter video sink
level: level: Level
omx: nvoverlaysink: OpenMax Video Sink
omx: nvhdmioverlaysink: OpenMax HDMI Video Sink
omx: omxvp8enc: OpenMAX VP8 Video Encoder
omx: omxh264enc: OpenMAX H.264 Video Encoder
omx: omxmpegaudiodec: OpenMax MP3/MP2 decoder
omx: omxaacdec: OpenMax AAC decoder
omx: omxwmvdec: OpenMAX WMV Video Decoder
omx: omxh263dec: OpenMAX H.263 Video Decoder
omx: omxmpeg2videodec: OpenMAX MPEG2 Video Decoder
omx: omxvp8dec: OpenMAX VP8 Video Decoder
omx: omxh264dec: OpenMAX H.264 Video Decoder
omx: omxmpeg4videodec: OpenMAX MPEG4 Video Decoder
typefindfunctions: video/x-pva: pva
typefindfunctions: application/x-ssa: ssa, ass
typefindfunctions: application/octet-stream: no extensions
typefindfunctions: application/x-yuv4mpeg: no extensions
typefindfunctions: audio/x-sbc: sbc
typefindfunctions: video/x-matroska: mkv, mka, mk3d, webm
typefindfunctions: image/webp: webp
typefindfunctions: application/vnd.ms-sstr+xml: no extensions
typefindfunctions: application/ogg: ogg, oga, ogv, ogm, ogx, spx, anx, axa, axv
typefindfunctions: audio/x-mod: 669, amf, ams, dbm, digi, dmf, dsm, gdm, far, imf, it, j2b, mdl, med, mod, mt2, mtm, okt, psm, ptm, sam, s3m, stm, stx, ult, xm
PLUGIN_NAME: nicesink: ICE sink
PLUGIN_NAME: nicesrc: ICE source
camerabin: wrappercamerabinsrc: Wrapper camera src element for camerabin2
camerabin: viewfinderbin: Viewfinder Bin
rtpmanager: rtpdtmfmux: RTP muxer
rtpmanager: rtpmux: RTP muxer
rtpmanager: rtpssrcdemux: RTP SSRC Demux
rtpmanager: rtprtxqueue: RTP Retransmission Queue
rtpmanager: rtpsession: RTP Session
rtpmanager: rtpptdemux: RTP Demux
rtpmanager: rtpjitterbuffer: RTP packet jitter-buffer
rtpmanager: rtpbin: RTP Bin
adder: adder: Adder
audioparsers: wavpackparse: Wavpack audio stream parser
audioparsers: sbcparse: SBC audio parser
audiofx: scaletempo: Scaletempo
tcp: multisocketsink: Multi socket sink
playback: uridecodebin: URI Decoder
playback: decodebin: Decoder Bin
playback: streamsynchronizer: Stream Synchronizer
playback: playbin: Player Bin 2
Total count: 109 plugins, 487 features
