Hi nvteam,
i had made two cfg files using pinmux spreadsheet
two files are
tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg and tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
and i got these files through the procedure below link
[url]https://devtalk.nvidia.com/default/topic/1031959/question-about-changing-tx2-pinmux-/#5261800[/url]
and then until recent, i used flash.sh command to apply the files above
just like this command form
$ ./flash.sh jetson-tx2 mmcblk0p1
but the command above was needed so much time and
the command below seems not perfectly applied the cfg files above to my tx2 board
$ ./flash.sh -r -k kernel jetson-tx2 mmcblk0p1
how i can update the cfg files to the tx2 board which are made using pinmux spreadsheet ??
