removed all cfg files in the bootloader dir and used “sudo ./flash.sh -r jetson-tx2-4GB mmcblk0p1” to tell me what cfg files were missing,
All I got was, it failed to tell me the missing files.
[ 0.4374 ] Generating br-bct
[ 0.4386 ] Updating dev and MSS params in BR BCT
File “./tegraflash.py”, line 1280, in
tegraflash_run_commands()
File “./tegraflash.py”, line 1149, in tegraflash_run_commands
interpreter.onecmd(command)
File “/usr/lib/python2.7/cmd.py”, line 221, in onecmd
return func(arg)
File “./tegraflash.py”, line 209, in do_flash
tegraflash_flash(exports)
File “/home/tbuckley/tmp/seattle_tx2_kernel/bootloader/tegraflash_internal.py”, line 258, in tegraflash_flash
tegraflash_generate_bct()
File “/home/tbuckley/tmp/seattle_tx2_kernel/bootloader/tegraflash_internal.py”, line 3424, in tegraflash_generate_bct
tegraflash_generate_br_bct(True)
File “/home/tbuckley/tmp/seattle_tx2_kernel/bootloader/tegraflash_internal.py”, line 3030, in tegraflash_generate_br_bct
run_command(command)
File “/home/tbuckley/tmp/seattle_tx2_kernel/bootloader/tegraflash_internal.py”, line 187, in run_command
info_print(’ '.join(cmd))
TypeError: sequence item 2: expected string, NoneType found
tbuckley@tbuckley-Latitude-3440:~/tmp/seattle_tx2_kernel/bootloader$ saving flash command in /home/tbuckley/tmp/seattle_tx2_kernel/bootloader/flash
saving: command not found
Terry
