We use SDK manager GUI generate JetPack_4.2.2_Linux_GA_P3489-0080 directory, but when we tried to generate the system.img with the above command, the error came out.
Are you modify the p2771-0000-0888.conf file?
The default DTB file is using tegra186-quill-p3489-0888-a00-00-base.dtb
And it can flash success on P3489-0080 platform via sdkmanager and flash command.
Please put your device into recovery mode with “–no-flash” command. Thanks!
# Copyright (c) 2018-2019, NVIDIA CORPORATION. All rights reserved.
# Redistribution and use in source and binary forms, with or without
# modification, are permitted provided that the following conditions
# are met:
# * Redistributions of source code must retain the above copyright
# notice, this list of conditions and the following disclaimer.
# * Redistributions in binary form must reproduce the above copyright
# notice, this list of conditions and the following disclaimer in the
# documentation and/or other materials provided with the distribution.
# * Neither the name of NVIDIA CORPORATION nor the names of its
# contributors may be used to endorse or promote products derived
# from this software without specific prior written permission.
# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS ``AS IS'' AND ANY
# EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
# PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
# CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
# EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
# PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
# PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
# OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
# (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
# OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
# p2771-0000-0888.conf: configuration for T186-A02 te770m P3489 SKU888
BPFDTB_FILE=tegra186-a02-bpmp-lightning-p3489-a00-00-te770m.dtb;
source "${LDK_DIR}/p2771-0000.conf.common";
EMMC_BCT=P3489_Sku888_4GB_Hynix_4GB_lpddr4_204Mhz_P138_A02_l4t.cfg
DTB_FILE=tegra186-quill-p3489-0888-a00-00-base.dtb;
TBCDTB_FILE=tegra186-quill-p3489-0888-a00-00-base.dtb;
PROD_CONFIG="tegra186-mb1-bct-prod-storm-p3489-1000-a00.cfg";
PINMUX_CONFIG="tegra186-mb1-bct-pinmux-quill-p3489-1000-a00.cfg";
PMIC_CONFIG="tegra186-mb1-bct-pmic-lightning-p3489-1000-a00.cfg";
PMC_CONFIG="tegra186-mb1-bct-pad-quill-p3489-1000-a00.cfg";
BOOTROM_CONFIG="tegra186-mb1-bct-bootrom-quill-p3489-1000-a00.cfg";
Yes, I am sure it are the below packages that I downloaded. Take easy, I am just curious about the command, “sudo BOARDID=3489 FAB=A00 ./flash.sh jetson-tx2-4GB mmcblk0p1”.
