When I look into jetson NX design guide I can find only 6 I2C bus, But when I check in NX through terminal it shows 11 I2C bus…
I have attached the screenshots here.
@WayneWWW
Can someone help me understand this ?
@WayneWWW
hello varun_pandithurai,
some of them as i2c multiplexer. you may see-also Topic 192486 for reference.
anyways,
please see TRM for [Table 10.20 I2C Controller Map].
you could also refer to device tree sources for reference,
for example, $public_sources/kernel_src/hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-i2c.dtsi
aliases {
i2c0 = &gen1_i2c;
i2c1 = &gen2_i2c;
i2c2 = &cam_i2c;
i2c3 = &dp_aux_ch1_i2c;
i2c4 = &pwr_i2c;
i2c5 = &dp_aux_ch0_i2c;
i2c6 = &dp_aux_ch2_i2c;
i2c7 = &gen8_i2c;
i2c8 = &dp_aux_ch3_i2c;
Hi @JerryChang ,
Is the device tree ( $public_sources/kernel_src/hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-i2c.dtsi) common for both Xavier AGX and NX?
yes, that’s a common device tree for t19x series. i.e. Jetson AGX Xavier and Xavier NX.
