Hi all,
We are working with a Jetson Xavier AGX and JetPack 4.6.2.
On our system, we need to use the I2C4 (i2c@3190000), which is I2C-3 in the system, to connect other devices but we are not able to use that bus with I2C Tools.
i2cdetect output:
i2cdetect -l
i2c-3 i2c 3190000.i2c I2C adapter
i2c-1 i2c c240000.i2c I2C adapter
i2c-101 i2c 15210000.nvdisplay I2C adapter
i2c-8 i2c 31e0000.i2c I2C adapter
i2c-6 i2c 31c0000.i2c I2C adapter
i2c-4 i2c Tegra BPMP I2C adapter I2C adapter
i2c-2 i2c 3180000.i2c I2C adapter
i2c-102 i2c 15220000.nvdisplay I2C adapter
i2c-0 i2c 3160000.i2c I2C adapter
i2c-7 i2c c250000.i2c I2C adapter
i2c-5 i2c 31b0000.i2c I2C adapter
Trying to use bus 3:
i2cdetect -r -y 3
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: – – ^C
The bus 2 works as expected so I wonder if this is something that I need to change in device-tree or other device affects this I2C bus to operate correctly.
We use a custom board but the same happens on the devkit.
Any help to enable this I2C bus will be appreciated.
Thanks in advance,
Greivin F.
